Will rev-matching wear out my clutch prematurely?
Old Dec 19, 2001 | 05:04 AM
gsr.sedan's Avatar
Default Will rev-matching wear out my clutch prematurely?
How long does the average stock clutch last? (assuming, no auto-x)
Old Dec 19, 2001 | 05:17 AM
HADA 11's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (gsr.sedan)
No, rev-matching, heel toe downshifting ect will not wear down the clutch prematurely, if done correctly.
The car should not become unsettled durring the downshift. If the shift isn't smooth it will effect the clutch.
I bought my car with 100,000 km on it, autox'd it, lapped it and drove it hard on the street, all on the original clutch.
Old Dec 19, 2001 | 10:57 AM
redteg1's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (HADA 11)
the clutch is there for a reason.....use it
Old Dec 19, 2001 | 11:19 AM
Black SVT's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (redteg1)
"the clutch is there for a reason.....use it "
Umm,WTF are you talking about?You use the clutch during a rev-match or when you downshift properly.I guess they didn't cover that in last months SCC,stupid ricer.
Old Dec 19, 2001 | 11:22 AM
Chris's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (Dc2k-specR)
As long as you are using the brakes to slow down the car, and not the engine (and clutch) then you will be fine.
Old Dec 19, 2001 | 11:30 AM
Flamenco-T's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (Chris)
rev matching is easier on your synchros...so yeah, when there are smooth engangement, your clutch is living easier than hard shifting (jerking..and etc..)
stan
Old Dec 19, 2001 | 11:54 AM
Black SVT's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (slipknot1)
Umm,clutches are cheaper than brakes?Since when?I would rather change my brakes than my my clutch anyday.Changing the clutch is very tedious and annoying.
Old Dec 19, 2001 | 01:06 PM
four27's Avatar
I am not sure what year Honda corrected it but the coil springs in the pressure plates in at least the 94 cars could come out of their spots. I think they went to a heavier spring retaining system later. so when you get a new clutch you get the better model I am told.
Old Dec 19, 2001 | 01:41 PM
junglistgsr's Avatar
Remember clutches are cheaper than brakes. Use the clutch
you sure about that?
Old Dec 19, 2001 | 03:57 PM
ingrate's Avatar
25 Year Member
Default Re: Will rev-matching wear out my clutch prematurely? (junglistgsr)
i guess if you count the costs of parts only, the clutch might be cheaper. but i'd rather change brakes over a clutch anyday!
Old Dec 19, 2001 | 09:39 PM
Mikex25's Avatar
New User
Default Re: Will rev-matching wear out my clutch prematurely? (In7egrity)
my clutch is squeeking why is that I have been doing some hard drag racing on it too.
Old Dec 19, 2001 | 09:58 PM
MachAF's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (sw388)
you must be those ricers that shift the automatic manually
Go clown on people elsewhere..troll
[Modified by machaf, 11:59 PM 12/19/2001]
Old Dec 20, 2001 | 07:37 AM
maggsgsr's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (machaf)
That little asshoe face is cool!!!!!!!!
Old Dec 20, 2001 | 10:02 AM
Flamenco-T's Avatar
I like your title....
mr takes the motor out to install turbo...
Old Dec 20, 2001 | 03:42 PM
sutrusu's Avatar
Default Re: Will rev-matching wear out my clutch prematurely? (Mikex25)
no you can't hear your clutch. thats your clutch pedal.
MachAF
Mar 14, 2003 03:46 PM
ALF
Nov 30, 2001 09:58 PM
