AEM CAI question
Old Oct 22, 2004 | 05:39 PM
Sabbotage's Avatar
Default AEM CAI question
After swapping my H22 into my 92 Si i ordered my AEM cold air intake which is supposed to work with 92-96 Si preludes or 93-96 VTEC ludes. AFter getting it i found that it has a hole in the top of it and no vacum line to go to this hole. Anyone got any input as to how to plug the hole? I dont want something getting injested into the intake and messing up my engine. Any help would be appreciated. Thanks
Old Oct 22, 2004 | 05:40 PM
Hawkze_2.3's Avatar
Default Re: AEM CAI question (Sabbotage)
Dremel off the nipple, JB Weld the hole
Old Oct 22, 2004 | 05:43 PM
Sabbotage's Avatar
Default Re: AEM CAI question (Hawkze_2.3)
There is no nipple. I just a hole and the intake comes with a rubber thing that pops in there and you slide a double sided nipple in there that also comes with the intake but it seems that everytime i go to put the nipple in, it pops the rubber piece down into the intake tube. Then i get pissed and have to rip the intake back off of the throttle body to get the rubber part out of there.
Old Oct 22, 2004 | 05:44 PM
Hawkze_2.3's Avatar
OK, just <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">JB Weld the hole </TD></TR></TABLE>
Old Oct 22, 2004 | 05:45 PM
Sabbotage's Avatar
That would be fine if it didnt look like crap after doing it. Id like to do it a much cleaner way. Im sure someone else has had this same situation? Anyone?
Old Oct 22, 2004 | 07:57 PM
Sabbotage's Avatar
anyone?
Old Oct 22, 2004 | 08:49 PM
limpmode's Avatar
is there no breather hose from your valve cover? that's what's supposed to hook up there. it's for emissions.
Old Oct 22, 2004 | 10:07 PM
Sabbotage's Avatar
Default Re: AEM CAI question (limpmode)
no this is a seperate hole aside from the connector for the hose to the valve cover. Its just a 1/4 inch hole in the tube right on top of the intake beside where the band slides on to connect it to the throttle body. Ive owned 2 5th gen ludes and installed AEM CAIs on both of them and neither of them had a seperate hole in the intake......so im a little confused. Ill try and take a pic tomorrow and post.
Old Oct 24, 2004 | 06:39 PM
limpmode's Avatar
only other thing i can think of is maybe a nitrous port. but if you ordered it new, they usually don't come with those. honestly, you would be fine for short term just taping over it. won't look too nice tho.
Old Oct 24, 2004 | 07:06 PM
BrokeLude's Avatar
Maybe for the Starting Air Valve? Mine didn't come with one even though it was supposed to...
Old Oct 24, 2004 | 07:58 PM
Sabbotage's Avatar
Default Re: AEM CAI question (BrokeLude)
yes! thats what its for and the H22 doesnt have one and i looked on my old H23 intake a lil bit ago and it does have that valve. So im trying to figure out a clean way to plug the hole since its just a hole with no nipple on it, but i want it to look good too. Im pretty stumped on what to use......hmmm
Old Oct 24, 2004 | 08:28 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sabbotage &raquo;</TD></TR><TR><TD CLASS="quote">yes! thats what its for and the H22 doesnt have one and i looked on my old H23 intake a lil bit ago and it does have that valve. So im trying to figure out a clean way to plug the hole since its just a hole with no nipple on it, but i want it to look good too. Im pretty stumped on what to use......hmmm </TD></TR></TABLE>
Can you post a pic?
We might be able to give you a better suggestion if we
know exactly what it looks like.
Old Oct 24, 2004 | 09:48 PM
jdmaek's Avatar
my aem v2 has it and i have a h23. I know the h22s only have to plug one thing into the intake, but the h23 theres another hoe u need to plug a little rubber to. I know the 5th gens dont have it either.
Old Oct 24, 2004 | 09:55 PM
BrokeLude's Avatar
Actually, my H22a1 has it...
Old Oct 24, 2004 | 09:56 PM
Sabbotage's Avatar
Default Re: AEM CAI question (SKDRCR)
yeah my car is 45 min away getting painted this week, but ill get a pic taken of it and post it when i go up there sometime this week
Old Oct 24, 2004 | 10:17 PM
Freemantle's Avatar
This intake is new? You're sure it's not tapped for Nitrous?
Old Oct 24, 2004 | 10:30 PM
Sabbotage's Avatar
Default Re: AEM CAI question (Freemantle)
no its not, its for the vacuum hose that the stick H23 has and my JDM H22 doesnt.
Old Oct 26, 2004 | 09:36 AM
honda9369's Avatar
dude the hole is for your intake air temp sensor
Old Oct 26, 2004 | 09:39 AM
Hawkze_2.3's Avatar
Default Re: AEM CAI question (honda9369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 &raquo;</TD></TR><TR><TD CLASS="quote">dude the hole is for your intake air temp sensor</TD></TR></TABLE>
*sigh* who's got a pooper scooper?...the IAT (intake air temp) sensor is on the opposite side of the plenum and has no vacuum anything on it.
Old Oct 26, 2004 | 09:47 AM
Monkey Fing a Coconut's Avatar
YES THE HOLE IS FOR THE STARTING AIR VALVE/AIR BOOST VALVE, h22a do not come with one, but a block off plate instead, h22a1 DO come with one, you can either cap it off or get a starting air valve/air boost valve and put it on your jdm manifold and connect the vac line, its not necessary though considering jdm doesnt come with one....but you will have to get one if you want to pass bar in cali
Old Oct 26, 2004 | 09:48 AM
five-0's Avatar
OMG. For all the H23's with intake son this site, I can't believe that I am reading this.
OK- It's for the AIR BOOST VALVE which someone has also already refered to as a "Starting Air Valve". Look at the vacum hose diagram sticker on your hood and it shows you how it routes.
As for plugging the hole- get creative, go to a plumbing store, or home depot, surely you aern't the first person to ever have to plug a hole. Good luck.
Old Oct 26, 2004 | 10:32 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">Actually, my H22a1 has it...</TD></TR></TABLE>
Old Oct 26, 2004 | 10:53 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: AEM CAI question (SuperSlow)
Vacuum plug that biatch!
Old Oct 26, 2004 | 11:47 AM
yeegsr's Avatar
that hole is for to connect the hole on the valve cover to the intake's little hole for vacumm release from valve cover....if you connect the intake will suck more vacumm off from the valve cover help the pressure under the valve stablized better and blah blah blah.
Old Oct 26, 2004 | 02:25 PM
SuperSlow's Avatar
Default Re: AEM CAI question (yeegsr)
Actually, no, it is not. If you read the above, you might STFU.
