flat tire...atts light...
Was the flat on one of the drive wheels?
If so, it sounds like you need to reset the ECU. If the computer senses one wheels spinning faster than the other it is going to disable the ATTS (ie. Flat Tire or Donut on the Front).
Just a word of advice, any time you get a flat tire, if it is one of the drive wheels, you should place a regular wheel on drive wheel location and put the donut in that one's place.
Good advice : If your ATTS unit senses different readings due to the "Donut" wheel that would cause the unit to trip and the light to come on, but if you try removing the clock/radio fuse or the Neg lead off the battery for 15 mins that should reset the ECU and remove the ATTS light.
ahhh i see thanks evvvverrrrrybody!
(this is my first car so i dont know much about fixin it buuuuuuuut..... i PROMISE to ASK as many questions as i can!! ahaha) thanks again
pez1
Nov 25, 2005 12:18 AM
piotrush
Jan 11, 2003 08:33 AM
