Type R and LS Thermostat, Thermoswitch, & Water Pump?
Old Oct 22, 2004 | 02:05 PM
AlienKrOZ's Avatar
Default Type R and LS Thermostat, Thermoswitch, & Water Pump?
Any difference from the Type R and LS Thermostat, Thermoswitch, & Water Pump? Will the Type R's be better for my LS.
Old Oct 22, 2004 | 03:02 PM
BlackOnBlackTeggie's Avatar
Default Re: Type R and LS Thermostat, Thermoswitch, & Water Pump? (AlienKrOZ)
the gear on the gsr and type r water pump is bigger then the LS thats all
Old Oct 22, 2004 | 04:04 PM
jDMJeRk's Avatar
Default Re: Type R and LS Thermostat, Thermoswitch, & Water Pump? (BlackOnBlackTeg)
just remember if you get a typer water pump you need to get a typer timing belt (unless they are the same im not sure)
Old Oct 22, 2004 | 08:25 PM
AlienKrOZ's Avatar
Default Re: Type R and LS Thermostat, Thermoswitch, & Water Pump? (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">just remember if you get a typer water pump you need to get a typer timing belt (unless they are the same im not sure)</TD></TR></TABLE>
would the type r water pump and timing fit onto the LS
Old Oct 23, 2004 | 06:17 AM
use the LS timing belt the type r and gsr heads are taller then the LS so the type R belt will be to long get a LS t-belt and u will be ok
Old Oct 24, 2004 | 01:31 PM
AlienKrOZ's Avatar
this is for a stock LS not a LSVTEC. is there any difference from the type r thermoswitch and thermostat? or should i just get one from pepboys.
just-ef-it
Jan 4, 2011 09:24 AM
soon2bdropped
Jul 22, 2007 11:33 AM
poch915
17
Feb 21, 2006 02:23 PM
wpsadmin
Oct 25, 2004 06:09 PM
warwagon
Apr 1, 2003 01:53 PM
