MSD Blaster 3 Coil and Ballast Resistor
Old Oct 22, 2004 | 01:55 PM
iiilgsrlll's Avatar
Default MSD Blaster 3 Coil and Ballast Resistor
I'm planning to run an external coil with the stock ignition system and AEM EMS. Is a ballast resistor required with the Blaster 3 coil? I've searched the archives and most say no but some people have used them.
I would like to hear from you guys before I install the coil. Thanks in advance.
Old Oct 22, 2004 | 03:15 PM
Import Tuna's Avatar
Default Re: MSD Blaster 3 Coil and Ballast Resistor (iiilgsrlll)
NO. Absolutely not.
Unless you are running a points type distributor.
Just my 2¢ worth.
IT
BTW, I like my Blaster2 coil. ANy reason why you went with the Blaster3?
Old Oct 22, 2004 | 04:44 PM
iiilgsrlll's Avatar
Default Re: MSD Blaster 3 Coil and Ballast Resistor (Import Tuna)
The only reason I went with the Blaster 3 is because that's what my friend sent me.
I believe your Blaster2 comes with a ballast resistor. Did you end up not using it?
Old Oct 23, 2004 | 02:40 PM
Correct.
DO NOT USE the ballast resistor.
It is for points type ignition. Not needed for Honda.
Actually, You can:
A. Throw it away.
2. Paint it pink and put it in a Halloween bag.
D. Save it for that old school lowrider bomb project you have been thinking about.
I hope someone thought this was funny.
IT
bloodgulch
May 4, 2006 03:23 AM
jdmotorsports
Apr 22, 2005 11:41 AM
iiilgsrlll
Oct 22, 2004 04:53 PM
Hayasa15
Aug 22, 2004 05:41 AM
