EG tranny problems
Old Oct 22, 2004 | 01:32 PM
inTeGra_LivesOn's Avatar
Default EG tranny problems
when i throw it in reverse it grinds a lot .. its not the normal kinda grind sound you hear .. sounds like its gonna break .. third gear pops out once and a while also .. was thinking about replacing the whole tranny but wanted some suggestions first .. any advice will help
Old Oct 22, 2004 | 02:21 PM
Targa250R's Avatar
be professional
Default Re: EG tranny problems (EGzR717)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGzR717 &raquo;</TD></TR><TR><TD CLASS="quote">when i throw it in reverse it grinds a lot</TD></TR></TABLE>
Are you coming to a complete stop before shifting into reverse? Have you tried selecting a forward gear before selecting reverse to make sure the input shaft stops spinning?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">third gear pops out once and a while also</TD></TR></TABLE>
Does it grind when shifting into 3rd?
Old Oct 22, 2004 | 02:30 PM
_Spugen_'s Avatar
Change the fluid and bleed the clutch resivore(sp?)....worked for me...
Old Oct 22, 2004 | 02:36 PM
D21X's Avatar
Default Re: (SpugenEG)
Yup u gotta do a complete stop, then hit reverse. Or when u first start up your car, throw it in first then hit reverse.
If not, think syncrhomesh would help???
Old Oct 22, 2004 | 02:50 PM
eg1VTEC's Avatar
That started happening to my car, and a week later I had no reverse anymore. Overtime I was having difficulty putting into reverse, and it made a bad grinding noise everytime that it did go. Turns out the synchros were totally shot, cost alot of money to replace that ****.
Old Oct 22, 2004 | 02:53 PM
Deemeetree's Avatar
Electrician
Place it in 5th gear, then Neutral, then Reverse. It will not grind.
Old Oct 22, 2004 | 02:57 PM
Targa250R's Avatar
be professional
Default Re: EG tranny problems (eg1VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg1VTEC &raquo;</TD></TR><TR><TD CLASS="quote">That started happening to my car, and a week later I had no reverse anymore. Overtime I was having difficulty putting into reverse, and it made a bad grinding noise everytime that it did go. Turns out the synchros were totally shot, cost alot of money to replace that ****. </TD></TR></TABLE>
Actually it couldn't have been synchronizers, since reverse isn't synchronized . . .
Reverse is the only gear in your transmission that doesn't have its teeth permanently meshed. Thus, you will actually mess up the teeth on the mainshaft gear and the idler gear if you constantly grind it. Once that happens, you have to tear down the mainshaft and replace it (what fun! ).
Old Oct 22, 2004 | 09:29 PM
thanks for the help .. well i tried the 5th then neutral then reverse .. didnt help .. and yea i know that i should be in a complete stop before going in reverse so that isnt it .. but i found out that the previous owner did a clutch job .. could he had done something wrong??
Old Oct 23, 2004 | 04:20 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGzR717 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help .. well i tried the 5th then neutral then reverse .. didnt help .. and yea i know that i should be in a complete stop before going in reverse so that isnt it .. but i found out that the previous owner did a clutch job .. could he had done something wrong?? </TD></TR></TABLE>
Yes, since there seems to be a shaft still spinning in there when it shouldn't be, it is more than likely that either the clutch was installed improperly, or some part of the cluth has failed prematurely (maybe a spring popped out or something).
First check the clutch hydraulic system. If everything looks okay with that, then you're probably going to have to drop the transmission to inspect the clutch itself . . .
Old Oct 23, 2004 | 06:38 AM
93CivicSI's Avatar
Default Re: EG tranny problems (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Have you tried selecting a forward gear before selecting reverse to make sure the input shaft stops spinning?</TD></TR></TABLE>
That is what I was thinking...
Old Oct 23, 2004 | 07:43 AM
Evs-One's Avatar
Solbros Owns Me
thats almost impossible. Keep your foot ON the clutch- go into a forward gear and then into reverse with your foot staying on the clutch. Like Targo said, this stops the mainshaft from spinning. There should be no way it would grind if a forward gear is selected first. It may be a little hard getting it into reverse if the teeth aren't lined up properly, but shouldn't grind- because no gears are spining
muhaMan
Jan 25, 2008 11:59 AM
wallawee
Jul 29, 2006 05:43 PM
shawn_crx
Jun 29, 2005 11:18 AM
LSEGHATCH
Feb 15, 2005 05:45 AM
Propulsion
Oct 18, 2003 08:40 AM
