having tranny problems need help!
Old Jan 12, 2008 | 01:31 PM
muhaMan's Avatar
Default having tranny problems need help!
car is 96 Integra GSR
ok, i was getting off the turnpike and i was slowing down so i switched into neutral and coasted for a little bit. I came to a complete stop and when i tried to put my car back in 1st gear it was stuck. I tried switching it into every other gear and the same result, i was stuck in neutral for a good 10 minutes.. while it was stuck my clutch felt dead and was really weak and my brakes were super hard and firm.
I know my synchros are shot cuz 2nd and 3rd gear grind like crazy. The weird thing is that after i get my car in gear, ALL of the gears go in smoother than ever. Anyone have any suggestions on wtf is going on?
Old Jan 25, 2008 | 10:58 AM
96'b20GsR4do's Avatar
Default Re: having tranny problems need help! (muhaMan)
Chit i wish i new it sounds like you have almost the same problem as i do, My tranny now also makes a loud "wobbling" noise not good. I can't figure out what it is but is sounds bad. Did you ever figure it out im realy curious
Old Jan 25, 2008 | 11:59 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: having tranny problems need help! (96'b20GsR4do)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96’b20GsR4do &raquo;</TD></TR><TR><TD CLASS="quote">Chit i wish i new it sounds like you have almost the same problem as i do, My tranny now also makes a loud "wobbling" noise not good. I can't figure out what it is but is sounds bad. Did you ever figure it out im realy curious </TD></TR></TABLE>
Does it only do it when the clutch pedal is out, But once you push it is it get alot quiter or goes away?
If so its your throwout bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muhaMan &raquo;</TD></TR><TR><TD CLASS="quote">car is 96 Integra GSR
I know my synchros are shot cuz 2nd and 3rd gear grind like crazy. The weird thing is that after i get my car in gear, ALL of the gears go in smoother than ever. Anyone have any suggestions on wtf is going on?</TD></TR></TABLE>
Hows your clutch fluid? I would make sure the lines are bled and you have enough fluid. Does your clutch slip at all, or is it getting towards the end of its life? Maybe you just need a new one.
egekreject
10
Aug 23, 2007 11:29 AM
xxmastermindxx
Sep 21, 2006 08:32 PM
Ned UK
15
May 25, 2005 04:59 AM
inTeGra_LivesOn
10
Oct 23, 2004 07:43 AM
itr1244
Sep 15, 2002 08:57 AM
