what does a p13 do that a p72 doesnt?
Old Dec 19, 2001 | 12:08 AM
sloaccord's Avatar
New User
Default what does a p13 do that a p72 doesnt?
i have a swapped accord, and my h22 has always idled at about 2k rpms while in motion- once i stop, the idle drops to a normal speed. when i tried a p72 for ***** and giggles, my high idle went away. same thing happened with a p28. what does the p13 sensor that the other two dont?
(ps, i left the p72 in; i sort of liked it. See any problems with that? maybe running lean because the ecu is designed for smaller injectors? TIA. . .. )
Old Dec 19, 2001 | 11:18 AM
sloaccord's Avatar
New User
Default Re: what does a p13 do that a p72 doesnt? (sloaccord)
come on; if you guys dont know, then no one will. . ..
Old Dec 19, 2001 | 11:22 AM
egghead's Avatar
I dont know why the idle went down, but i do know that the p72 ecu runs leaner. Thats probably why you liked it, of course you could just get a fields or vafc and tune your old ecu and get the same results.
Old Dec 19, 2001 | 11:42 AM
Katman's Avatar
it has to do with a fast idle valve or somthing thereof that has to do with a vacuum sensor. The P13 ECU looks for that- the P72 doesn't.
Old Dec 19, 2001 | 09:00 PM
sloaccord's Avatar
New User
Default Re: what does a p13 do that a p72 doesnt? (Katman)
hmph; i think thats pretty close. I was throwing a code 14 (idle air control) with my first ecu [a jdm ks-rom re-chip] but tried a stock jdm p13 to see if that would fix the problem ( it didnt) then the stock ecu threw a code 7 (TPS) and i've tried both a p28 and now two different p72's, which dont blow any codes.
thank god for beer, or i'd have ripped out my hair by now. . . .
Old Dec 19, 2001 | 09:40 PM
sgT's Avatar
sgT
Fast idle valve doesnt have any sensors. COmpletely mechanically controlled.
H22A/F22A does have an EGR which the other ECUs dont control.
I dont know if that would have anything to do with it though.
Old Dec 20, 2001 | 08:08 AM
Jason kiDD's Avatar
Hey sloaccord I would be interested in one of the spare p72's or p28's if you still have them. Get back to me. Would be willing to trade for my p13 that is giving no problems at the moment. Looking into the Hondata setup instead of getting a Controller.
Old Dec 20, 2001 | 09:51 AM
Katman's Avatar
Default Re: what does a p13 do that a p72 doesnt? (sgT)
...yeah that's what I meant EGR, and yes it does through a check engine light. I forgot which sensor it was...thanks.
Old Dec 20, 2001 | 12:15 PM
sloaccord's Avatar
New User
Default Re: what does a p13 do that a p72 doesnt? (Jason kiDD)
sorry, i only have spare p13's, no extra p72's or p28's. sorry!
Old Dec 20, 2001 | 12:20 PM
Jason kiDD's Avatar
That is okay, any USDM ones..????
Old Dec 20, 2001 | 09:20 PM
sloaccord's Avatar
New User
nope. i have the stock jdm p13, and the rechipped jdm p13.
Old Dec 21, 2001 | 07:42 AM
Jason kiDD's Avatar
Aight then thanks any ways. And good luck with your car.
mikeunreal2
31
Mar 12, 2006 10:28 PM
BeerBaron105
Jun 7, 2005 02:22 AM
89_crx
Apr 18, 2005 06:26 PM
Nextelbuddy
Apr 29, 2003 09:37 PM
