when trying to install tranny I heard pop noise...
Old Oct 22, 2004 | 09:19 AM
turbosi03's Avatar
Default when trying to install tranny I heard pop noise...
after sliding the tranny on the motor it stops with about 1/2" gap left between tranny and motor. while holding the tranny up with one hand I put in the bolts hand tight and then started tightening the bolts...
I noticed at first it was not even and while I kept turning bolts to try and make it even I heard a pop noise from the tranny, I tried a few moer times and heard about 5 pops total.
I loosened all the bolts and started over again and it finally went on smoothly.
so my question is what were the "pops" and did I mess up the tranny?
I used the alignment tool that came with the clutch to mount the pressure plate...
thanks for any input!
Old Oct 22, 2004 | 09:56 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: when trying to install tranny I heard pop noise... (turbosi03)
Honestly I would say you are fine
Did you inspect the trans after removing it the 2nd time?
Old Oct 22, 2004 | 09:58 AM
pngfolife's Avatar
Default Re: when trying to install tranny I heard pop noise... (si2die4)
There are two dowel pins that position the bellhousing onto the engine block. Sometimes they get rusty or they may have been misaligned and as you tightened the housing bolts, they slid into place.
Old Oct 22, 2004 | 11:00 AM
turbosi03's Avatar
Default Re: when trying to install tranny I heard pop noise... (pngfolife)
yes I looked inside the bell housing and at the bearing in the flywheel. I wasn't sure if the shaft hit the bearing on the fw and maybe that pushed the gears somehow... I'm pretty sure it wasnt the dowel pins making the noise, it was comming from inside the tranny case. which still makes me worried
keep the ideas comming
Old Oct 22, 2004 | 11:05 AM
DaX's Avatar
DaX
Loved
Community Favorite
Check the end lash on the tranny main shaft. You may have screwed something up internal.
Old Oct 22, 2004 | 12:27 PM
turbosi03's Avatar
Default Re: (DaX)
damn that means I have to take the tranny off again
I definately will do it now rather then after its in the car... anyone know what the end play specs are for the tran main shaft?
do other people agree I should do this? or am I over paranoid...
Old Oct 22, 2004 | 01:06 PM
mattssi's Avatar
paranoid. If it is already bolted to the motor, Then slap the rest of it together. If you get it all back together and something is messed up, then start to take it back apart, but I doubt that there is anything wrong.
Old Oct 22, 2004 | 01:46 PM
Bailhatch's Avatar
Default Re: (mattssi)
probably the disc catching on the splines or maybe the release fork settling on that little post. Your probably fine.
Old Oct 22, 2004 | 06:17 PM
turbosi03's Avatar
Default Re: (Bailhatch)
ok I feel better a little... I'm dropping this motor in the car tomorrow
jdm702
Transmission & Drivetrain
May 18, 2010 09:27 PM
lsturbo*
Mar 3, 2008 02:02 PM
Nisif
Aug 20, 2005 04:39 PM
Nisif
Aug 20, 2005 08:26 AM
triggerX
Apr 24, 2004 12:03 AM
