FS: 52mm Greddy EGT Gauge (everything minus EGT Probe **85.00 Shipped)
as the topic says, i purchased a second EGT gauge because i couldn't get my original to work. i wasn't sure if it was the gauge or the probe so i purchased a second unit and found it to be the probe that wasn't working properly.
*the unit i'm selling has NEVER been used, it is BRAND NEW.
*an egt probe can be found for 30-40 dollars.
here is a pic of what i have...
here is the probe...which will work with this gauge...
TRE sells an egt probe for 45.00 shipped.
here is a link: http://www.teamrip.com/accessories.html
TRE K-type Exhaust Gas Temp Probes
Compatible with all 2 wire K-type gauges. (Apexxi, Autometer, Blitz, Greddy, HKS, Ispro, Percys, VDO, Westach)
For racing applications where tuners demand fast accurate EGT data.
Designed with a small exposed junction encased in a thin low mass sheath to provide the fastest response possible, this high quality replacement will maximize the performance of your EGT GAUGE.
There is no time for slow responding EGT probes in a high power race engine unless you have time to find the slagged pistons in the oil pan. Seriously you should buy this bitch and see what you've been missing.
The EGT probe is short, stout and is durable enough to handle severe exhaust pulse energy without failure.
Accuracy: +/- 14°F @ 1400°F.
Max continuous temp: 1785°F.
Max temp: 2200°F.
Thread type: Industry standard 1/8" NPT - 27 t.p.i. This is a common tap that can be purchased at any local hardware store.
Response: .18 sec/100° F If you're data logging Exhaust Gas Temps this EGT probe is a MUST. Junction is When you really want to know what is happening you need this EGT probe.
Wire length included with probe: 18"
Probe comes with 18 inch lead of stainless steel braided EGT wire and mini-jack terminal that allows easy hook up to your existing EGT wire. Additional wire listed below.
Includes installation instructions and a 1 year warranty.
Modified by chet at 3:32 PM 10/29/2004
Max temp: 2200°F.
blackcivic44
Mar 12, 2005 12:59 PM
Rob03Pro5
Nov 19, 2001 08:18 AM
