LS/VTEC TIMING
Old Oct 22, 2004 | 07:46 AM
HondaVTEC93's Avatar
Default LS/VTEC TIMING
I was wondering if theres any suggestion to timing a LS/VTEC setup without dyno runs. The engine currently has:
JDM B16 head
AEM adj. Cam Gears
Integra Type R intake manifold
headerback exhaust
unorthidox pulleys
ngk plugs and wires
aem fuel rail w fuel press. reg.
intake
vtec kicks in at 4400rpms
safc (not tuned)
B18B block
Old Oct 22, 2004 | 08:01 AM
BauleyCivic's Avatar
Risky Business
Default Re: LS/VTEC TIMING (HondaVTEC93)
Just keep it at stock until you're dyno'ed...cam gear timing only adds 2-3 HP after A/F tuning anyways.
Ignition timing keep at 16 degrees.
Old Oct 22, 2004 | 08:08 AM
WAFFLES's Avatar
Default Re: LS/VTEC TIMING (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Just keep it at stock until you're dyno'ed...cam gear timing only adds 2-3 HP after A/F tuning anyways.
Ignition timing keep at 16 degrees.</TD></TR></TABLE>
I concur....
Old Oct 22, 2004 | 03:39 PM
mugencivic99's Avatar
hey man i also have a 16a head and a ls bottom end with some other things.. witch water pump did u go with a used the b16 and a b16 tiiming belt and it times out right, but i have the skunk gears just for back up.
Old Oct 23, 2004 | 08:14 AM
WAFFLES's Avatar
Default Re: LS/VTEC TIMING (mugencivic99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic99 &raquo;</TD></TR><TR><TD CLASS="quote">hey man i also have a 16a head and a ls bottom end with some other things.. witch water pump did u go with a used the b16 and a b16 tiiming belt and it times out right, but i have the skunk gears just for back up.</TD></TR></TABLE>
You can't use a b16 timing belt on an lsvtec. It wont fit, you need a gsr or itr belt. And definitely use the VTEC water pump and oil pump.
Old Oct 25, 2004 | 07:59 AM
Default Re: LS/VTEC TIMING (WAFFLES)
everything runs right, the car runs faster cause i retarded the VTEC cam (exhaust cam on the jdm b16a's, intake on the newer si's) 4 degrees and advanced the intake cam 4 degrees and its running much better than at a top dead 16 degrees. and yes the water pump was changed over, and the timing belt is integra i believe
Old Oct 25, 2004 | 08:03 AM
WAFFLES's Avatar
Did you check the ignition timing to see where it was after the cam tuning?
Old Oct 25, 2004 | 06:10 PM
not yet i know it changes w cam timing, but i ran out of time, top end is good at 4400 when vtec engages and torque's still strong surprisingly for a honda...last time i checked the ignition timing it was dead center, we'll see this time...i know i can get more out of this motor.
88.REX
Nov 4, 2009 12:38 PM
Dppope
Apr 13, 2009 06:58 AM
blackcrx16
Sep 15, 2007 11:18 PM
Zatzy
Apr 16, 2006 11:08 PM
