Auto to Manual: Clutch/Brake Pedal Assembly
Hello,
So I'm pretty set on doing an auto. to manual conversion this coming up weekend. I've done a bunch of research on exactly the parts that i need and some of the basics and what needs to be done. However, I haven't been able to find specifics on how to install the clutch/ brake assembly. Everything just says that you need to install it. So i was looking for some pictures/ diagrams with whats all involved and if its absolutely needed to drop the steering column. I would like to avoid the extra work of all that if possible. Another thing that i haven't seen much info on is installing the master cylinder. Is it just like a bolt or two?? I haven't bought all the parts yet so i'm not even sure what the master cylinder looks like. Any help or last minute advice would be great and much appreciated.
Thanks
Thanks
1.remove the plastic covers under steering wheel and there should be 2 bolst holding it down and 4 bolts on a metal plate. 2.master cylinder bolts right up with 2 bolts, holes are there already just take a black plastic off and your set. 3.pedals have about 5 bolts, 4 firewall and 1 I think 1 on top. good luck
Vincent.
Jun 5, 2006 10:04 PM
