what can cause a car not to start???? help please????
Old Dec 18, 2001 | 10:13 PM
ysrhatch's Avatar
New User
Default what can cause a car not to start???? help please????
okay car has compression, car has gas, car is timed perfect, car has sparks, car has oil, car has coolant. but i dont know y the car wont start?? please i need some major help. can anyone help please.
Old Dec 18, 2001 | 10:28 PM
Trickturn's Avatar
Default Re: what can cause a car not to start???? help please???? (ls_vtecer)
Check your grounds to the engine & to the tranny.
Pete
Old Dec 19, 2001 | 10:00 AM
chi1874436's Avatar
Default Re: what can cause a car not to start???? help please???? (pest)
pull out the rail w/injectors to see if the fuel is firing thru the injectors.
make sure everything is at TDC.
ign timing set.
check distributor.
check fuel pump/filter
ground
leakdown/compression
Old Dec 19, 2001 | 10:02 AM
Charles B.'s Avatar
Default Re: what can cause a car not to start???? help please???? (chi1874436)
Make sure all sensors are hooked up.
Old Dec 19, 2001 | 10:27 AM
chi1874436's Avatar
Default Re: what can cause a car not to start???? help please???? (SuperDuperEG)
also, what does your car sound like when trying to crank it over. Give me more detail as what it sounds like- hope it's something simple as the battery, starter, or alternator.
Old Dec 19, 2001 | 12:07 PM
mdouglas's Avatar
88-91 Civics and CRX's can have this problem if the 2 white wires at the distributor are switched. One is supposed to have a red piece of tape on it to help identify, but it's usually not there so it is easy to get them mixed up if you pop them out.
Holds true for the ZC swaps on that generation and probably other swaps too. It cranks over and sounds fine, just never starts up.
Also, check the firing order and make sure the plug wires are correct, but that's usually obvious though when you try to crank it.
Old Dec 19, 2001 | 01:00 PM
hired gun's Avatar
Pest: I had the same damn problem and I kept telling myself that there was something missing in that area of the egine compartment. Sure enough it was the damn ground.
I changed the batteries 3 times cuz it sounded like the car was dead!!
Yep, check yer ground!!!!
Old Dec 19, 2001 | 01:09 PM
Aceman64's Avatar
is it getting fuel to the rail? mine wasnt and it gave me alot of headaches......if it is are the injectors squirting? there again mine werent.....thats what mine ended up being.....and the fuse for the efi was good, but just wasnt getting good contact?? wierd
BolivianFuego
Apr 9, 2011 09:34 AM
uncle joe
Jun 28, 2008 11:03 PM
b16a4
Apr 26, 2007 06:21 PM
Zion-I
Jan 24, 2007 07:34 AM
delphi-dada
Apr 5, 2005 04:09 AM
