Missing under light load. Plug gap issue?
Old Oct 22, 2004 | 03:56 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Missing under light load. Plug gap issue?
My car has been running excellent on the exact same setup and hondata tune for the past few months. Recently is has started to miss and stumble pretty bad under light load but immediately smooths out under boost. However I'm not getting any misfire codes.
My part throttle tune is very rich (just got a rom burner and wideband is on the way to fix that) and I just recently changed my plugs, but I gapped them the same as always (.32). Would a tighter gap possibly help the problem?
Old Oct 22, 2004 | 07:10 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Missing under light load. Plug gap issue? (ActiveAero)
Gapp um at .30 and then .28 and see what happens
What are you running as far as ignition goes? Stock igniter? If so Have you changed it recently?
Old Oct 22, 2004 | 10:06 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Missing under light load. Plug gap issue? (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">Gapp um at .30 and then .28 and see what happens
Yeah it' stock and no telling when it was last changed. That's probably something I should look into.
Old Oct 22, 2004 | 10:53 PM
Drew Peacock's Avatar
I would say its a tuning issue not spark related if it was to miss fire it would be under heavy load normally right up top. Because as it is you are running a fairly generous gap. Weather getting cooler.?
Old Oct 22, 2004 | 11:10 PM
SOHC_MShue's Avatar
I may be having a similar issue...now that it has gotten cold.
Double Agent
Mar 24, 2009 02:46 PM
ohsnapzafingcu
26
Apr 27, 2008 07:01 PM
6SPD_EK
Mar 7, 2007 06:22 AM
92civichatchsir
Sep 22, 2005 10:53 AM
ms1motorsports
Aug 25, 2004 08:48 AM
