i bought Supertech pistons...anyone else use them?
Old Oct 21, 2004 | 10:39 PM
ojoemamao4o's Avatar
Default i bought Supertech pistons...anyone else use them?
Supertech pistons are manufactured from extruded high silicon, enhanced 4032 alloy that low thermal expansion, excellent wear resistance and higher thermal conductivity. A phosphate dry lubricant coating is applied to pistons to protect against ring micro welding and ehance skirt lubrication
Supertech Performance has more than 30 years of experience under its belt in the design of racing pistons and the utilization of the latest CAD software & Finite Element Analysis enables them to design strong high-performance lightweight pistons for each application. Supertech pistons are manufactured from extruded high-silicon, enhanced 4032 alloy (with additional Cu, Ni & Mg) that has low thermal expansion, excellent wear resistance and higher thermal conductivity. A three step forging process yields a fine structural grain oriented in fibers in the same direction of the stresses. Several heat treatments provide the piston with a high tensile strength and evenly distributed hardness that will withstand boost up to 42psi. The slugs are CNC machined with special diamond tools for dimensional precision, perpendicularity and flatness of the ring grooves. Contact reduction grooves are standard. A “phosphate dry lubricant” coating is applied to protect the rings against “micro welding” and enhance lubrication on the skirt/cylinder area.
copy pasted...they were on an introductory sale at the shop i go to for 350!!! i couldnt pass it up...i went supertech because they have a good backround with engine performance, hope these pistons a can hold up...wondering if any out turbo b18s are running this setup for turbo, i bought 81.5mm 9:1 compression
Old Oct 21, 2004 | 10:53 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: i bought Supertech pistons...anyone else use them? (ojoemamao4o)
Last time I saw some they were very heavy. But that doesnt mean that the final product are heavy.
Old Oct 21, 2004 | 11:00 PM
Rob Dizzle's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (Arturbo)
I remember hearing about the project like 18ish months ago
cool to have something out. its interesting, because there are alot of other piston comapnies out there already. but if they are going to be marketing with a cost leadership styles (lowest price pretty much) then it could be a hot seller
Old Oct 21, 2004 | 11:14 PM
Default Re: i bought Supertech pistons...anyone else use them? (Bob-DC2)
yeah, im liking the thermal coating
i was getting cp pistons, 440 but when i called the shop to order then they told me about this deal 350 for the supertech psitons....awesome
all i need now are oem gaskets and seals for the bottom and top end then i can putt her all back together
Old Oct 22, 2004 | 12:25 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Last time I saw some they were very heavy. But that doesnt mean that the final product are heavy. </TD></TR></TABLE>
Even if they are, us low revving LS guys don't care much about rpms like you slow VTEC guys do. A little extra weight doesn't mean so much
Old Oct 22, 2004 | 01:55 AM
GLHS895's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (J. Davis)
last i heard hypereutetic (silicon-alloy) pistons suck for boost. crack, fall apart. you name it, they do it.
of couse, this is just what i've been told. i've only seen it in one instance, and it was in a kragens brand 'recon' motor. we all know those are budget motors, naturally they use budget materials (hypers are cheaper to make).
i'm willing to bet they've developed a bit and can take some boost(heat) now. the ad specifically says 42psi
Old Oct 22, 2004 | 04:22 AM
Oyvind Ryeng's Avatar
Is it just me or does those ringlands look dangerously thin?
Old Oct 22, 2004 | 05:35 AM
.nate's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (GLHS895)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GLHS895 &raquo;</TD></TR><TR><TD CLASS="quote">last i heard hypereutetic (silicon-alloy) pistons suck for boost. crack, fall apart. you name it, they do it. </TD></TR></TABLE>
Are you sure these pistons are hypereutectic?
Old Oct 22, 2004 | 06:29 AM
Freemantle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ojoemamao4o &raquo;</TD></TR><TR><TD CLASS="quote">yeah, im liking the thermal coating
Those aren't thermal coated in the jet-hot sense. That would be stupid. If the heat isn't in your piston, theat leaves more to be in the sleeves and combustion mixture.
If I blow up this block, I might look into those. Building a block is stupid expensive.
Old Oct 22, 2004 | 06:36 AM
Finland's Avatar
Let us know how they work out.
Old Oct 22, 2004 | 06:48 AM
Enthalpy's Avatar
I love posts like this...
"Hey guys i just dumped my life savings on part X from brand Y. is part X from brand Y any good? Or am i screwed like altar boy making an afterhours visit to his priest?"
HAHAHA...hope they work out for you man...it's only your engine afterall. what can go wrong?
Old Oct 22, 2004 | 09:05 AM
done's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (Enthalpy)
sorta stupid questino? are those foruged?
Old Oct 22, 2004 | 09:10 AM
miller's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (Jordo)
supetech pistons huh? can you give us anymore info about them?
they look like Mahle pistons.....
Old Oct 22, 2004 | 09:13 AM
B00ST2nR's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (miller)
not sure about their pistons, but I've heard nothing but GOOD things about their Valvetrain components.
Old Oct 22, 2004 | 10:38 AM
GLHS895's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure these pistons are hypereutectic? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ojoemamao4o &raquo;</TD></TR><TR><TD CLASS="quote"> Supertech pistons are manufactured from extruded high silicon, enhanced 4032 alloy</TD></TR></TABLE>
Old Oct 22, 2004 | 10:42 AM
Substitute the word "detonation" for "boost" and you win a cookie!
Then again, most any piston sucks for detonation...
Old Oct 22, 2004 | 11:13 AM
FredoSP's Avatar
its good to see another product come to the market
Old Oct 22, 2004 | 11:25 AM
Default Re: i bought Supertech pistons...anyone else use them? (FredoSP)
well they should be in this weekend or at the latest, beginnning of next week, all i need now is engine seals and gaskets then i can start putting her all back together, i have a personal goal of starting the engine by halloween...ill try to shoot some pics thanks guys for the comments
Old Oct 22, 2004 | 11:38 AM
LoSt is BlaCk's Avatar
the coating still scares me...i have seen them work before but i could not bring my self to using those...
Old Oct 22, 2004 | 12:22 PM
GLHS895's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Then again, most any piston sucks for detonation...</TD></TR></TABLE>
it damn well better be an oreo!
common mistake. but i'm sure the general consensus is: hypers = crack easy with detonation. sure, if you tune it to perfection and you always drive during good conditions then i'm sure they'll work fine. but how many people have it that good?
Old Mar 9, 2009 | 08:21 AM
DRtools's Avatar
I wonder how well the 11.9:1 pistons would work with a built N/A ls-vtec.
Old Mar 9, 2009 | 08:37 AM
92redhatch's Avatar
bringing back the dead!
Old Jul 17, 2009 | 12:21 PM
Rease3's Avatar
^^^fail super dead thread.
Old Jul 17, 2009 | 04:36 PM
purpleh22's Avatar
Supertechs have been around for quite a while. haven't heard that they are any more (or less) problematic than other popular brands. No those aren't hypereutectic.
jerrys7583
Jun 15, 2012 08:00 PM
IIXtremeHansen
33
Apr 15, 2008 08:42 AM
Wheelman-CZ
Jan 7, 2008 12:52 AM
TurboT
Nov 28, 2001 01:42 PM
