Door swap out?
A buddy of mine wrecked his EX and had the doors in alrite condition and since i have a DX hatch i wanna put power locks and windows onto my car. My question is after i move the parts over what wiring do i need to do in order to get this stuff working properly? I would move the doors over but i hear that trying to get them balanced out is just hard. Help anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b16 »</TD></TR><TR><TD CLASS="quote">im pretty sure you need his whole floor wiring harness but i may be wrong
youll need the harness to make it easier. then youll have to run some wires to the relays/fuses under the dash.
</TD></TR></TABLE>youll need the harness to make it easier. then youll have to run some wires to the relays/fuses under the dash.
Replacing the whole cabin harness will be a bitch. If you have AC, you will have to purge the system.
One way to do it is go to a junk yard and just cut the end of the harness that connect the cabin to the door. From there you could lengthen the wires you'll need for the windows and locks. Fuse the necessary lines and get power from the accessory section of the fuse box. The harness will pug strain to the door.
Yeah, floor harness. Also, if you use the EX floor harness, (and I think) you won't be able to use your rear window wiper unless you wire it up yourself.
Here, go to my buddy's How-To on my cous' site... http://www.clubek.net/forum/viewtopic.php?t=101
monicle
May 13, 2003 07:46 AM
