how much will it cost to fix this..
Old Oct 21, 2004 | 07:54 PM
crxsi8's Avatar
Default how much will it cost to fix this..
was putting on header and this came off, how much will it cost me to fix.....
Modified by crxsi8 at 9:16 PM 10/21/2004
Old Oct 21, 2004 | 07:55 PM
rice_classic's Avatar
Default Re: how much will it cost to fix this.. (crxsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">was putting on headers and this came off...
Is the hole blocked/stripped/threaded??? We need more information.
If you can remove and install your own headers you should be able to answer this question.
Those exhaust studs come out all the time... just screw it back in with 22 ft/lbs of tq.
Old Oct 21, 2004 | 07:56 PM
91sihatchback
Guest
Posts: n/a
headers? what is that a v6? a header you mean! oh yea.....
crxsi8's Avatar
Default Re: (91sihatchback)
its a a6..the thingy came off..
Old Oct 21, 2004 | 07:57 PM
crxsi8's Avatar
Default Re: how much will it cost to fix this.. (rice_classic)
i think stripped..ill show some more pics
Old Oct 21, 2004 | 08:03 PM
crxsi8's Avatar
this is how the screw looks like..
Old Oct 21, 2004 | 08:09 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (crxsi8)
The exhaust stud broke..
Left-hand drill bit or an extractor&gt;might work..
civicdust's Avatar
just put some jbweld in the hold, and dont worry about it (if you plan to keep the header).
Old Oct 21, 2004 | 08:10 PM
crxsi8's Avatar
how much will it cost for a replacement..does anyone know?
Old Oct 21, 2004 | 08:14 PM
gaydm.accord's Avatar
2 bucks for a new stud give or take, but getting it out could cost you 10 bucks at a muffler shop or find someone with a reverse drill bit and take it out.
and its header not headers.
and im willing to bet that when you installed that header you didnt follow the proper removal pattern. move in then out and then out then in for reinstall or was it the other way around.
NismoMugen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback &raquo;</TD></TR><TR><TD CLASS="quote">headers? what is that a v6? a header you mean! oh yea.....</TD></TR></TABLE> &lt;--- example of a smart ***
Old Oct 21, 2004 | 08:17 PM
crxsi8's Avatar
will anything bad happen..will it leak..cause its not leaking yet?
Old Oct 21, 2004 | 08:18 PM
yea it'll leak
Old Oct 21, 2004 | 08:26 PM
crxsi8's Avatar
Default Re: (gaydm.accord)
will i loose any performance..will it cause any damage to the engine.
Old Oct 21, 2004 | 08:41 PM
SEA Hag's Avatar
Start it up and if it sounds like a diesel truck don't drive. If it sounds normal take it to someone that knows what there doing and don't drive until they fix it. Either way u need to fix it asap. U could do it yourself, but if you were capable of this u probably would have already done it.
Old Oct 21, 2004 | 08:42 PM
crxsi8's Avatar
Default Re: (SEA Hag)
do you know if the engine needs to be taken out to be fix..
Old Oct 21, 2004 | 08:50 PM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEA Hag &raquo;</TD></TR><TR><TD CLASS="quote">Start it up and if it sounds like a diesel truck don't drive. </TD></TR></TABLE>
no engine can stay put
I'll put my flame suit on just incase but:
why no header? i've been thinking of intead of buying a $100 chery bomb muffler just run the motor header-less to get the loud atention getting sound i want.
Old Oct 21, 2004 | 09:03 PM
mrspeaker's Avatar
Default Re: (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">
1.If u dont use an exhaust manifold the valves will fry and **** up ur motor..
2.Too noisey
3.too dirty and smelly
4.U would have to be completey retarded to do that..
Old Oct 21, 2004 | 10:53 PM
GSRCRXsi's Avatar
Default Re: (Mrspeaker)
lol, ive been running with my stud broken in that exact same place for a while. doesnt leak as far as i can tell. i did use some sealant on it. i do want to fix it but i know its gonna be a pain in the *** and ive been putting it off, ive got the stud and everything
Old Oct 21, 2004 | 10:55 PM
crxsi8's Avatar
Default Re: (GSRCRXsi)
how much do you think it be to replace it..is it causing any problem
Old Oct 21, 2004 | 11:00 PM
camboMONK's Avatar
I had the same problem at the exact location. Tap out broken stud and replace with a new one. If you are afraid of doing it, have a friend, who know what he doing, help you out.
Old Oct 22, 2004 | 02:35 AM
NFM_Dm's Avatar
Default Re: (camboMONK)
bolt extracter from home depot or lowes worked for me.
Old Oct 22, 2004 | 02:57 AM
NikoZai's Avatar
Default Re: (sekz)
LOL im laughing so hard cuz this poor kid is so paniced about a broken bolt. Like the people that werent too busy making fun of you said "Get an extractor" Homedepot... ask around, someone will tell you how to use it. It takes some elbow grease so if you're afraid you're permanently damage the engine you wont succeed... So my advice is to stop being a ***** and drill that ****** out it wont leak fluids.. just make sure you're drilling the bolt and not the block. An exhuast leak is all that will be wrong with your car until you fix it, you'll probably be fine if you didnt remove other bolts. Muffler shops will fix lil **** like that for you for cheap so long as you don't go in there saying words like "thingy" in which case they will charge you 50$ anything more than 20 and you know you look like a sucker. K
Old Oct 22, 2004 | 03:21 AM
mrspeaker's Avatar
Default Re: (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">LOL im laughing so hard cuz this poor kid is so paniced about a broken bolt. Like the people that werent too busy making fun of you said "Get an extractor" Homedepot... ask around, someone will tell you how to use it. It takes some elbow grease so if you're afraid you're permanently damage the engine you wont succeed... So my advice is to stop being a ***** and drill that ****** out it wont leak fluids.. just make sure you're drilling the bolt and not the block. An exhuast leak is all that will be wrong with your car until you fix it, you'll probably be fine if you didnt remove other bolts. Muffler shops will fix lil **** like that for you for cheap so long as you don't go in there saying words like "thingy" in which case they will charge you 50$ anything more than 20 and you know you look like a sucker. K </TD></TR></TABLE>
He's speaking the truth ,,listen to him..
Its not such a big deal like ur makin it out to be..
Old Oct 22, 2004 | 08:05 AM
wait til he blows his motor =s
ouch**
