B18B1 supercharger on B18A1 motor??????
hey I want to install a supercharger on my 1992 Inegra Ls but can not find one that I want to use. I would like to install a Jacksonracing supercharger that's designed for the B18B1 and want to know if I can install it on my car. I want to know what the diffrence is between the A1 and the B1 head. thanks
It should fit on the B18A1, but you'll have trouble fitting it into a G2.
A few people have done this on G2IC.com, but they had to do a lot of massaging to make it fit properly in our engine bays. It's already cramped compared to a G3 bay as is...
Check out g2ic.com, someone on the forums may have a write-up for doing this. But as far as your question, yes, it will fit the motor, but only if it's swapped into a different car.
From: Derek Jeter drinks wine coolers,, The Nation, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic_z »</TD></TR><TR><TD CLASS="quote">It should fit on the B18A1, but you'll have trouble fitting it into a G2.
Check out g2ic.com, someone on the forums may have a write-up for doing this. But as far as your question, yes, it will fit the motor, but only if it's swapped into a different car.</TD></TR></TABLE>
Yeah I have heard there were a ton of problems, but I don't remember with what. Hit up G2ic.com
The master cylinder, some hardlines, proportioning valve, along with a LOT of vacuum lines all get in the way.
The only person i know that did it successfully was B17aVORTECH. I'm not sure if his writeup is still there...
