cant find a timing belt to fit!!!!! help!
Old Oct 21, 2004 | 05:58 PM
soslowsi's Avatar
Default cant find a timing belt to fit!!!!! help!
I put a `90 dx head on a `93 vx block, vx timing belt does not fit! it has 103 teeth. what belt should I use????
Old Oct 21, 2004 | 06:10 PM
daidilus's Avatar
Default Re: cant find a timing belt to fit!!!!! help! (soslowsi)
last time i checked..you would have to use the belt for the head.........so get a 90DX timing belt!
Old Oct 21, 2004 | 06:13 PM
soslowsi's Avatar
Default Re: cant find a timing belt to fit!!!!! help! (daidilus)
it was too small also, tried a belt off a 1.6 motor and it was too big.
Old Oct 21, 2004 | 10:18 PM
signorelli21's Avatar
check this out, your in luck because i work at a parts store, and i ran into the same problem swapping my d16a6 head on my y7 block weird **** i know, but i found that on honda timing belts each tooth is about an 1/8in. so tell me what length(aka how many teeth/width) you need and i will help. on my problem i had the belt off my original motor(d16y6) was one toothe too long and the y7 belt was too short, so i got a belt 106 tooth for an accord or something.
Old Oct 22, 2004 | 04:49 PM
soslowsi's Avatar
Default Re: cant find a timing belt to fit!!!!! help! (signorelli21)
I ended up getting a 39inch belt that was 1inch wide, it worked great.
sohchatch
Dec 26, 2020 11:32 PM
slide inside
Oct 22, 2009 09:25 AM
unbelievableEG
11
Sep 26, 2007 08:41 PM
93civicEX
Jul 11, 2005 07:48 PM
