Lowered==> Correct Alignment
Old Oct 21, 2004 | 05:51 PM
red99ex's Avatar
Default Lowered==> Correct Alignment
My 99' ex is lowered on Goldline springs around a 2" drop not really sure. I want to put adjustible suspension parts on in order to get the vechicle to factory specs in order to get it aligned properly. What parts are avalible and where? I am currently running NITTO NEO GEN tires to help compensate for the camber problem. Please give any advice.
Old Oct 21, 2004 | 05:55 PM
EJ8Joel's Avatar
Default Re: Lowered==> Correct Alignment (red99ex)
Get an Ingalls camber kit.
Old Oct 21, 2004 | 06:33 PM
nighttrain33's Avatar
Default Re: Lowered==> Correct Alignment (JDMJoelEK)
Go to http://www.mmrusa.com or any aftermarket car shop and they should be able to get some kind of camber kit for you. Ingalls is good, that's what I have and they work just fine. Skunk2 also makes a camber kit. It doesn't matter what kind of tires you have, it won't "compensate" for camber. It will just be more expensive to replace them when they are worn.
-Shane
DKYamada
Suspension & Brakes
12
Mar 21, 2009 06:29 AM
E36 Guy
16
Apr 7, 2006 09:58 AM
crx1009
Apr 5, 2006 09:57 AM
Arv
Nov 5, 2004 01:41 PM
toooslow
May 7, 2003 12:38 PM
