VTEC Solenoid?
Old Oct 21, 2004 | 05:19 PM
VTECPowerdSi's Avatar
Default VTEC Solenoid?
My vtec stopped working about 2 days after i got my oil changed on my car i ran a diagnostics and oil pressure is at 50lbs and the vtec light comes on around 5800 what else could it be could it be the solenoid?
Old Oct 22, 2004 | 12:07 AM
drussell4801's Avatar
Default Re: VTEC Solenoid? (VTECPowerdSi)
my vtec stopped working right after I changed my oil one time, so i figured it was the vtec oil pressure sensor screen becoming contaminated by the new oil or some ****.
It turned out I had pulled loose one of the grounds.
don't assume it's the oil.
Old Oct 22, 2004 | 06:44 AM
Default Re: VTEC Solenoid? (drussell4801)
My vtec light comes on around 5500rpm though (at least thats what the mechanic said) so could it still be a loose ground wire or something even tho that it still engages vtec but doesnt kick in?
Old Oct 22, 2004 | 11:35 AM
could be one of many things. A loose ground wire could be it.
Old Oct 24, 2004 | 10:11 AM
how do i check if its a loose ground wire??
Old Oct 24, 2004 | 12:09 PM
W.O.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECPowerdSi &raquo;</TD></TR><TR><TD CLASS="quote">My vtec stopped working about 2 days after i got my oil changed on my car i ran a diagnostics and oil pressure is at 50lbs and the vtec light comes on around 5800 what else could it be could it be the solenoid? </TD></TR></TABLE> its the crankshaft rings making detonation in the exhaust of the supercharger causing the 4th stage VTEC lobes to not engage the rota slipstreams, while the intake valve butterflies float
Old Oct 24, 2004 | 12:26 PM
MR-MUGEN's Avatar
Default Re: VTEC Solenoid? (1quickLS)
what motor is it b16 or b18
Old Oct 24, 2004 | 03:12 PM
Default Re: VTEC Solenoid? (jdm92daintegra)
b18c jdm
Old Oct 24, 2004 | 03:14 PM
W.O.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra &raquo;</TD></TR><TR><TD CLASS="quote">what motor is it b16 or b18</TD></TR></TABLE> does it matter?
Old Oct 24, 2004 | 04:28 PM
i dunno but my oil pressure is at 50psi could that have something to do with it
Old Oct 24, 2004 | 04:29 PM
Keno20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote"> its the crankshaft rings making detonation in the exhaust of the supercharger causing the 4th stage VTEC lobes to not engage the rota slipstreams, while the intake valve butterflies float </TD></TR></TABLE> thats what I thought.
Hope you dont mind me siggn it??
Old Oct 24, 2004 | 05:14 PM
Drian's Avatar
Something in same effect happened to me. I had a cel 21. Changed the oil and now after 3days it went out. I also checked all wires and plug fittings also.
Old Oct 24, 2004 | 05:18 PM
17GSR17's Avatar
Default Re: (Drian)
damn what oil are u guys using so I wont
Old Oct 24, 2004 | 05:46 PM
W.O.P.'s Avatar
Default Re: VTEC Solenoid? (Keno20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keno20 &raquo;</TD></TR><TR><TD CLASS="quote"> thats what I thought.
Hope you dont mind me siggn it??</TD></TR></TABLE> no problem
Old Oct 24, 2004 | 07:18 PM
MR-MUGEN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote"> does it matter?</TD></TR></TABLE>
ya if he had a knock sensor
blacktibby07
May 14, 2011 11:12 AM
JSpekBB4
Oct 30, 2007 10:23 PM
THC07
Oct 4, 2006 06:05 AM
05 S2K Stoner
Oct 28, 2004 06:39 PM
Chuji
May 12, 2002 10:42 AM
