is this a good fully built h22 set up?
Old Oct 21, 2004 | 04:03 PM
whp
Guest
Posts: n/a
Default is this a good fully built h22 set up?
https://honda-tech.com/zerothread?id=1030700
Old Oct 21, 2004 | 04:08 PM
speedracer9k's Avatar
Default Re: is this a good fully built h22 set up? (throwed)
why, are you trying to get an idea on how you want to build your car? Turbo or NA? If your going turbo, then yes...that's a good set-up
Old Oct 21, 2004 | 04:13 PM
whp
Guest
Posts: n/a
Default Re: is this a good fully built h22 set up? (speedracer9k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer9k &raquo;</TD></TR><TR><TD CLASS="quote">why, are you trying to get an idea on how you want to build your car? Turbo or NA? If your going turbo, then yes...that's a good set-up</TD></TR></TABLE>
sry, but obviously i met turbo because of the low compression. i met are the parts used (sleeves,pistons,rods,ect...) are good, anyone have a set up similar to this?
Old Oct 21, 2004 | 04:18 PM
h22 civic's Avatar
axels will own joo :
Old Oct 23, 2004 | 06:46 PM
Default Re: is this a good fully built h22 set up? (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">axels will own joo :</TD></TR></TABLE>
good point! make sure you upgrader your axles too, and yes that is a good set-up
Old Oct 23, 2004 | 07:54 PM
ludegetsmwet's Avatar
I recommend polishing and balancing the crank, and upgrading the valvetrain to. if your serious and maybe have some miles on the motor then replace the bearings to. other than that the setup looks decent.
jetlude
Oct 10, 2007 06:03 PM
vietkidracing
Jun 13, 2006 01:37 AM
icebergli
Apr 17, 2006 10:30 PM
huge230
Feb 10, 2006 12:14 PM
StraightCivic
Mar 29, 2005 07:38 AM
