how to find TDC on each cylindar?
How do i find tdc for each cylindar, do i just turn the crank a half turn for eacy cylindar or what? I can find TDC for cylindar 1 but what about the others?
yes, 1/2 turn of crankshaft for each cylinder - with marks on pulley at TDC for #1, turn crank 180 degrees and you will be TDC on #3, another 180 degrees (marks on pulley again at top) and you will be TDC on #4, another 180 and you will be TDC on #2, another 180 and you will be back at TDC on #1.
Pull spark plugs out and turn crank pulled with a long thing peace of metal resting on pistons. As the long rod of metal moves up wait right before it starts to go down that is tdc for each piston.
DEF
DEF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">yes, 1/2 turn of crankshaft for each cylinder - with marks on pulley at TDC for #1, turn crank 180 degrees and you will be TDC on #3, another 180 degrees (marks on pulley again at top) and you will be TDC on #4, another 180 and you will be TDC on #2, another 180 and you will be back at TDC on #1. </TD></TR></TABLE>
this is correct I do this with a rachect and 19mm socket
easy
easy
Project_ED8
Dec 2, 2003 03:28 PM
