Difference Between Universal Turbo muffler and Non Turbo Muffler
Old Dec 18, 2001 | 07:35 PM
YumYumRoLL's Avatar
Default Difference Between Universal Turbo muffler and Non Turbo Muffler
I know that 5 Zigen makes two different Fireball mufflers, one is the regular one and the other is the Turbo muffler... will it make a difference if I used a turbo muffler instead of the regular muffler if I am not running turbo or anything?
Old Dec 18, 2001 | 07:36 PM
Chris's Avatar
Default Re: Difference Between Universal Turbo muffler and Non Turbo Muffler (mr clean 4dr)
I think the Turbo is larger diameter. Dont get it if you are not Turbo... It will hurt the performance..its too large.
Old Dec 19, 2001 | 11:43 PM
EkREV's Avatar
New User
Default Re: Difference Between Universal Turbo muffler and Non Turbo Muffler (Chris)
turbo muffler is going to be bigger than the non-turbo one. overall diameter, tip size, and piping will be bigger. go with the N/A muffler if your car is going to be N/A.
Old Dec 20, 2001 | 07:34 AM
YumYumRoLL's Avatar
Default Re: Difference Between Universal Turbo muffler and Non Turbo Muffler (EkREV)
i see, okay thanks alot, i just wanted to know because the TIP on the turbo fireball looks alot better because its longer.... thanks anyway...
Old Dec 20, 2001 | 11:04 AM
TrustGs-R's Avatar
New User
yes. the turbo one has a 3 inch diameter inlet.
if you're NA or boosting under 8psi, you'd be better off with the 2.5inch diameter max.
bh2285
Aug 1, 2006 04:04 PM
zumiez007
Dec 20, 2004 11:41 PM
DRKSol
Aug 29, 2003 07:32 AM
loki2323
Jan 16, 2003 09:03 PM
