Coilovers vs. Lowering springs
Old Oct 21, 2004 | 12:07 PM
DesertCivic's Avatar
Default Coilovers vs. Lowering springs
I am not really sure on this topic, being the reason why I am asking. What are the best to have, Coilovers or Springs?
Old Oct 21, 2004 | 12:10 PM
JDMallTHEway's Avatar
Default Re: Coilovers vs. Lowering springs (DesertCivic)
I have springs right now, but it really depends on what you want.
you can't adjust ride height with springs, but u can with coilovers.
Old Oct 21, 2004 | 12:15 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Either are great, but the key is having new struts that are matched well for the spring rates (how stiff the springs/coil-over springs are) in order to ride nicely.
What year car do you have?
What type of wheels/tires are on the car?
What type of drop are you looking for?
What type of driving do you do most?
Do you have others that ride in the car a lot (wife, kids, girlfriend, mom) that might influence the type of ride quality you need?
How much money can you afford to spend on the new suspension?
Old Oct 21, 2004 | 12:24 PM
R Thizzel's Avatar
Default Re: Coilovers vs. Lowering springs (B18C5-EH2)
95 civic EX, Racing hart C2 w/nitto450, 2" in the front 1.8 in back, daily city driving, only have one other seat in the car, i can prolly spend up to 900
how bout that?
Old Oct 21, 2004 | 12:26 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Coilovers vs. Lowering springs (R Thizzel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">95 civic EX, Racing hart C2 w/nitto450, 2" in the front 1.8 in back, daily city driving, only have one other seat in the car, i can prolly spend up to 900
how bout that?</TD></TR></TABLE>
What type of ride quality are you looking for?
Old Oct 21, 2004 | 12:28 PM
R Thizzel's Avatar
well right now i have sprint lowering springs on and they ride pretty dam smooth for lowering springs. id rather have it a little stiffer and reduce the body roll
Old Oct 21, 2004 | 12:46 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">well right now i have sprint lowering springs on and they ride pretty dam smooth for lowering springs. id rather have it a little stiffer and reduce the body roll</TD></TR></TABLE>
Well if you have $900.00 to spend I'd look into the Bilstein/Neuspeed full coil-overs. They usually run about $750.00-$800.00 and they ride awesome on my wife's 1992 Si HB. They are very high quality and come with everything you need except for the top hats/upper mounts.
So far I'm very impressed with them. They ride firm, but not bouncy one bit. the only drawback I can think of is that the car won't sit up very high even if you try to raise the coils up because the Bilsteins er shorter than most struts. The reason they are shorter is to have the car low, but still offer full travel. Longer struts will allow a higher ride height, but if you ride pretty low the travel is limited and you're more likely to bottom out.
That make sense?
Old Oct 21, 2004 | 01:38 PM
R Thizzel's Avatar
yea i was lookin at a set of tein basics the other day. you know anything about those?(quality, spring rates, if it includes everything)
Old Oct 21, 2004 | 01:50 PM
Chunty Butt Kevin's Avatar
Springs = Take it or leave it drop, bouncy (after a while), cheap (if your on a budget)
Coilovers = Adjustable, adjustable shocks (if you buy the good ones), expensive
I'd get the coilovers and go for the infamous HT tire tuckage.
Most people here do a hybrid of Ground Controls with Konis or KYB
Old Oct 21, 2004 | 02:07 PM
R Thizzel's Avatar
Default Re: (SoFa king Fast)
im not getting KYBs at all. my homeboy had the agx and the rod broke in half. tein basics or tanabe ss are the one that have caught my eye so far
Old Oct 21, 2004 | 02:16 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (R Thizzel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">im not getting KYBs at all. my homeboy had the agx and the rod broke in half. tein basics or tanabe ss are the one that have caught my eye so far</TD></TR></TABLE>
Tein Basics suck ***.
Tein SS are nice. My pal has some on his EG (his SN is egcellent here on H-T) and they seem to be pretty sweet.
The Bilstein/Neuspeed set-up is cheaper and probably every bit as good as the more expensive SS though.
BTW:
KYB makes excellent dampers despite your friend's experience. I find it very hard to believe that the rod just simply broke on it's own. There more to it I'm sure, because I've ran KYBs on various cars of mine since 1999 and I still own a set on my 90 hatchback and they're great. I had a set for 3 years, wore them out, then had them replaced for FREE because of their lifetime warranty.
You won't get a lifetime warranty like that with other brands...
Old Oct 21, 2004 | 02:23 PM
cyb3rjak's Avatar
Default Re: (B18C5-EH2)
i hear adding in some frame locks make your lowered ride much much better + handelin
Old Oct 21, 2004 | 02:49 PM
CivicEG R's Avatar
This is such a noob question, but do coilover kits such as the tein ss come with new shocks/struts.?
Old Oct 21, 2004 | 04:09 PM
cyb3rjak's Avatar
Default Re: (CivicEG R)
indeed
Old Oct 21, 2004 | 04:40 PM
phillycx's Avatar
I have a GC/Koni Yellow set-up that I use for daily driving and auto-x about twice a month. I would say that spending between $800-1000 dollars for suspension (this includes front and rear camber kits [I only have the rear]) isn't worth it unless your going to be adjusting your suspension. If your just going to slap it on and leave it I would go with one of the more inexpensive set-ups like the GC/Bilstein that was suggested or KYBs. If you are patient and look around you'll get'em cheap.
Old Oct 21, 2004 | 04:43 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (cyb3rjak)
What are your thoughts on frame locks Tom?
Old Oct 21, 2004 | 05:33 PM
skunk2eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEG R &raquo;</TD></TR><TR><TD CLASS="quote">This is such a noob question</TD></TR></TABLE>
noobs, calling noobs, noobs...priceless!
Old Oct 21, 2004 | 06:19 PM
mrchaos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Either are great, but the key is having new struts that are matched well for the spring rates (how stiff the springs/coil-over springs are) in order to ride nicely.
How much money can you afford to spend on the new suspension?</TD></TR></TABLE>
94 Hatch CX
GSR Rims
Toyo T1-S
2" MAX drop
Mostly street, smooth ride but can handle feeling some bumps
Girlfriend
~ $1000
Old Oct 21, 2004 | 06:24 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
coilovers are adjustable, where as springs are just 1.5 drop, 2.0 drop, no adjusting.
Old Oct 21, 2004 | 07:32 PM
Default Re: Coilovers vs. Lowering springs (mrchaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos &raquo;</TD></TR><TR><TD CLASS="quote">94 Hatch CX
GSR Rims
Toyo T1-S
2" MAX drop
Girlfriend
~ $1000</TD></TR></TABLE>
tein coilovers. thats what you need.
Old Oct 21, 2004 | 07:44 PM
vdub08's Avatar
eg coupe
17 racing hart c5s kumho ecstas now, 16" with falken azenis
im running some stiff *** springs with stock shocks (about a 2" drop) right now that crap is bumpy as hell
im fine with the 2" drop but im getting new skirts soon so a 1 or 1.5 would be good
i drive like 95% street. i have a lot of bumpy streets though and my roads are all filled with bad seams (no consideration for us lowered cars )
i want some stiffness but not as much as im experienceing now only enough to reduce some body roll
i have 1-2 friends in there once in a while
gimme some options
Old Oct 21, 2004 | 07:53 PM
Nova_Dust's Avatar
For coilover, unless you are on the track most of the time, you rarely adjust the height. But it is there for you do the adjustment when you need it. If you are confortable with a set height then get a decent strut and lowering spring.
As for brand and spring rates, you need to do some homework on that part. A lot of combos out there, it is hard to say which one suits you best until you read more into it. Buying suspension can be harder than picking out a girl's gift sometimes.
Old Oct 21, 2004 | 08:00 PM
hondainspired's Avatar
Default Re: (Nova_Dust)
i personally like the idea of springs better but... i love a sweet drop... and i can personally vouge for the fact that you need a good strut to match the spring...
Old Oct 21, 2004 | 08:07 PM
90civichb's Avatar
Default Re: (hondainspired)
my cut springs are stiff as hellllll-o everybody!
I bought my car with cut springs but its actually not too bad now that Im used to it.. Doesn't bounce, doesn't bottom out, doesn't rub, doesn't clunk or anything..
I know its ghetto but until I can afford struts and springs, im not gonna risk changing it..
A friend of mine has the tein SS on his 95 civic coupe.. they ride pretty nice, I don't know what he has them set on or the ride height..
TEIN
cut springs -- GayDM
Old Oct 21, 2004 | 08:37 PM
RVCA97's Avatar
Default Re: (90civichb)
right now im running tokico illuminas w/ sprint lowering springs cost me around 500 total
