Please help me with my choice!! (cams)
Old Oct 21, 2004 | 11:51 AM
MastahB16's Avatar
Default Please help me with my choice!! (cams)
Hello, i am from the netherlands so sorry for the faults in my writing
This is my setup till now
b16a2
invidia exhaust system
Mugen 4-1 header
B&m fuel pressure modifier
Skunk2 intake manifold ported
BBK 70mm Throttle body
Str Fuel rail
Tenzo R intake
My next step will be camshafts. But there aren't many N/A tuned cars here so i asked it here.
What kind are the best for street racing and wild enough to use the 70mm perfect.
Some said to me Type R are the best ad best performans but i thought Toda B or Skunk2 stage 2 or JUN3 are superb cams with the best performence?
Does anyone have good argument, i also want to make a lot of RPM and will change the springs enz.
Thanks
Dennis
Old Oct 21, 2004 | 11:57 AM
DEVIOUS_EG*'s Avatar
Default Re: Please help me with my choice!! (b16a2DENNIS)
go with some CTR's or the 00-01 ITR's...
and btw, welcome to H-T...
Downey's Avatar
whoa, its been a long time since ive seen a member from Holland..
i used to live there.. from 90 till 1997. I lived close to Hilversum. My pops worked in Utrecht and Apeldoorn.
anyway.. a set of 2000-2001 Integra Type R or Civic Type R camshafts would be great in your B16. Skunk2 stage 1's or 2's would make good power too, but you will need to get it dyno tuned.
My choice.. get some Buddy Club 3+.
Old Oct 21, 2004 | 12:02 PM
MastahB16's Avatar
Thanks for the welcome!!!
But are type R cams really faster than a pair of aftermarket cams like skunk2 stage 2 or for example Spoon.
Because honda made them to make 200.000miles they where not so wild.
Thanks again.
Greetings den
Old Oct 21, 2004 | 12:06 PM
for what you have, then yes...
dam, 70mm tb?
Old Oct 21, 2004 | 12:23 PM
MastahB16's Avatar
That's a normal reaction 70MM !!!
Hahaha
But it works fine the intake sound is superb a i don't have problems in every rpm.
I don't now how it works with a 65mm but they told me that i will have advantage when getting wild cams.
Greetzzz den
Old Oct 21, 2004 | 03:33 PM
stevieteg's Avatar
70mm tb???
what is the sk2 im ported to?
with stock compression I'd suggest the itr or ctr. Anything more aggresive would be over camming the motor and you probably would not be happy with the end result. Start with a mild lift cam. You can always upgrade later, after a healthy compression bump.
Old Oct 22, 2004 | 03:54 AM
MastahB16's Avatar
It was ported to fit the 70mm better and they polished some things but i don't know much about these thiongs i now that there are bigger holes
The type r cams are perfect i see.
I go check some prices and keep ya all in touch!
Gr. Den
Old Oct 22, 2004 | 03:59 AM
svistras's Avatar
even the CTR /ITR cams wont work a 100% with stock compression 10,2:1..
Maybee you should consider a compression raise to use other cams
gary_vtec
Jul 8, 2011 08:28 PM
93EG6SI
Dec 3, 2005 12:36 AM
drewruberry
Jan 19, 2005 06:33 AM
londa hover
Aug 1, 2004 11:33 AM
JDM CRX
Jul 4, 2002 11:37 PM
