NEED HELP 88 HARNESS INTO A 90 CRX SI??????
Guest
Posts: n/a
Like the topic says I needed a motor for my 90 si and I went and bought a 88 si. well most of the connecters worked except for the 2 by the injector resistor box. can any one help me with a wiring diagram? and I dont have the 90 wiring harness anymore. thanks guys and girls.
can some one please put up a diagram of the harness from the block and right of it? for both years please.
Modified by eLUDEnu at 3:40 PM 10/21/2004
can some one please put up a diagram of the harness from the block and right of it? for both years please.Modified by eLUDEnu at 3:40 PM 10/21/2004
why did the plugs not fit? I have a 91 harness in my 89. So far the only problem I had was that the reverse light was not where the it was suppose to be so I had to rewire it. I believe I have a 90 crx si factory manual at work I'll see if I can do anything else.
I hope this helps. I have an 89 Si that Im finishing up and used a 88 Si Harness ( cars not done yet but heres what ive been told )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">what you have is 88 Si harness - you can de-pin the square connector and put the round connector on the harness - just make sure the wire colors match on both sides of the connector - the square 88 connector has less wires since the 88 Si didn't have a fast idle control valve - the chassis harness side will have a darker blue wire that isn't used</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikitad »</TD></TR><TR><TD CLASS="quote">Another thing that will need to be done - on the pass. side shock tower big round plug.
In your engine harnessm besides all other wires, it will have a Red/yel wire next to Red/white wire. The 6-wire plug next to the round plug will have Blue/yellow next to Blue/green wires. These two pairs will need to be swapped over:
Blue/yell swaps places with Red/yellow
Blue/green swaps places with Red/white.
You'll see on the car side of the plugs, there will be wiires of the matching colors, so you'll be able to verify it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepersRus »</TD></TR><TR><TD CLASS="quote">why did the plugs not fit? I have a 91 harness in my 89. So far the only problem I had was that the reverse light was not where the it was suppose to be so I had to rewire it. I believe I have a 90 crx si factory manual at work I'll see if I can do anything else.</TD></TR></TABLE>
88 Si has a square 6 pin connector - 89-91 Si has a round 8 pin connector - this is because the 89-91 Si had a Fast Idle Control Valve and 88 Si didn't - thus the extra wires
yes, sort of - black with yellow stripe is "hot" with ignition on - just make sure it isn't grounding out on anything
1990whitecrx
Sep 26, 2010 10:10 AM
harlen
11
May 29, 2008 09:36 AM
