Brake problem...please help
Old Dec 18, 2001 | 06:15 PM
KhRoNiX's Avatar
Default Brake problem...please help
I was changing the pads on my sisters TL and she pushed the brake while the caliper was off and the piston fell out. I dont know how to get it back in. Please help. Its the rear brake by the way. TIA
Old Dec 18, 2001 | 06:26 PM
rainforest's Avatar
Default Re: Brake problem...please help (KhRoNiX)
did you rember to put the retainer clip cack in that goes between the pads, and did you put the caliper in the slots that it sits in, also you pushed the brake pedal all the way down to decompress the piston.
Old Dec 19, 2001 | 06:02 AM
REDBARON's Avatar
Default Re: Brake problem...please help (rainforest)
Call an Acura service department and ask a Tech. If I'm not mistaken all you do is put the seals back on the piston and then push it back into the caliper. But call a tech, I'm sure they will help.
P.S. Don't have you sister helping you out next time.
Old Dec 19, 2001 | 08:55 AM
rainforest's Avatar
Default Re: Brake problem...please help (VTECHatch)
you usually dont have to take the seals off.
Old Dec 19, 2001 | 10:18 AM
Perfectionist's Avatar
The rear pistons kind of "screw" back in, not just push in like the fronts.
ksweetland
Suspension & Brakes
12
May 18, 2012 03:19 AM
leviq
Jul 7, 2007 08:28 AM
HGZ
Sep 6, 2004 11:14 AM
MygirlsCoupe
Aug 10, 2004 08:58 AM
Oct 31, 2002 10:37 PM
