idle problem: revving up to 4k at idle fluctuating
Old Oct 21, 2004 | 08:01 AM
2SlowDC's Avatar
Default idle problem: revving up to 4k at idle fluctuating
95 integra ls
stock b18b
what would cause the idle to rev up to 4 k at start up? it revs up to 4 k then starts to fluctuate to 2 grand then goes up to 4. it does this with 2 second intervals.
Old Oct 21, 2004 | 09:25 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: idle problem: revving up to 4k at idle fluctuating (lsVtec...)
sounds like a small leak in the vaccum line
Old Oct 21, 2004 | 09:31 AM
2SlowDC's Avatar
ive had vaccum leaks b4 but this hasnt been the result of one. are u sure?
Old Oct 21, 2004 | 11:24 AM
GSRNetics's Avatar
Yeah, you gots a vaccum leak somewhere. Had the same problem with my 88' Accord beater. When just ideling it would always jump up and down in revs. Sorta sucks when your next to rice machines cause they think you wanna race
::EDIT:: On another thought it might be your throttle body as well. Might have something stuck in there causeing it fluctuate. Mechanic can prolly clear it out for you, if not, you need a new one.
Old Oct 28, 2004 | 12:31 PM
sp00led's Avatar
Default Re: idle problem: revving up to 4k at idle fluctuating (93DALS)
think i had same prob on my old 87 accord it was slow idle valve was a pretty cheap fix.
Old Oct 28, 2004 | 01:38 PM
b16a2delsol's Avatar
same thing happend to my car...... check your "idle air control vavle" its right under your TB .....you're going to need to take it apart to see the problem.... its 5 bolts all together noo biggie...
bestofthe80s
May 7, 2017 05:21 PM
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
sun_zinc
Jul 13, 2008 01:19 PM
hondachris1994
Mar 3, 2006 06:49 AM
4doorB18Bcivic
Nov 17, 2002 03:56 PM
