hesitation/bogging ??!!
Old Oct 21, 2004 | 07:08 AM
1point5CRX's Avatar
Default hesitation/bogging ??!!
heres the problem im running into. i have a sohc zc -nonvtec, swap. its always ran good but lately its seems like its been having a bit of a hesitation and bogging at part throttle, usually under 3k rpms. if i give it full throttle itll slowly clear up and start to pull again. i changed the cap, rotor and plugs. ive had my fuel regulator set at what it is for a while so i dont think thats it. i sort of have it narrowed down to maybe a tps problem or ignitior in the dizzy. the car throws no cel though. also, it never does this when i baby the car around. as soon as i punch it once, the bogging and such begins to happen when im just crusing.
anyone had this happen??
Old Oct 21, 2004 | 07:13 AM
mrspeaker's Avatar
Default Re: hesitation/bogging ??!! (1point5CRX)
Your cat might be clogged..If u have one
Old Oct 21, 2004 | 08:55 AM
1point5CRX's Avatar
Default Re: hesitation/bogging ??!! (Mrspeaker)
it just seems like something electrical, if the cat was bad, shouldnt it do that all the time, most of the time it runs great
Old Oct 21, 2004 | 10:53 AM
B16 ED9's Avatar
I had a similar problem on my D16A6 ended up being the dizzy, I replaced the dizzy, problem solved
Old Oct 21, 2004 | 02:07 PM
C-RICKS's Avatar
DUDE!
Im going thrugh the exact same thing right now. I too drive a ZC sohc non-vtec.
You just describbed the same thing my car is doing. I check and re-did the timing belt, changed plugs,changed cap and rotor, messed with throttle, ect.ect....
Oh, and i did the timing belt again last night, just to make sure
I am so fucken stumpped!!! It feels like it's not getting enough gas or maybe not enough air. The car has been doing this for a week and a half now. I'm just about to lose my job if i don't get this **** fixed! I think tonite maybe i'll pull all wire harnesses and redo all the wiring!!!
Could it be a relay? Tps? fuel pump?
For the record, i was considering removing my silencer to see if that would help free something. Cause the thought of catalictic being clogged did cross my mind.
Thanx guys
Old Oct 21, 2004 | 03:18 PM
bigblueandyellow's Avatar
I came across this problem too, so i added a fuel pressure gauge inside the engine bay.... ran it off a large hose and watched it inside while i was driving, it seemed that i would get a lag in the fuel pressure when i stomp on it.....i still have this problem maybe someone can enlighten us on what part to replace
Old Oct 21, 2004 | 03:27 PM
shawn_crx's Avatar
Default Re: (bigblueandyellow)
might be a air leak.
check your intake manifold t/b to see if any air leaks.
Old Oct 21, 2004 | 03:46 PM
EJ2-Fluffy's Avatar
Default Re: (shawn_crx)
Bump it up...This is the exact problem I'm having when mashing my pedal early in the morning. I can hear the Air Intake suck in air but it seems the gas just isn't getting lit up correctly. Almost like a timing issue but I highly doubt it.
-Jon
Old Oct 21, 2004 | 04:39 PM
ThatRicerDaniel's Avatar
Default Re: (CRX-Fluffy)
miss fire? injector wiring on wrong injector?
Old Oct 21, 2004 | 04:53 PM
OptimusPrimeX's Avatar
just out of curiosity, did you do a compression test?.. easy test, small tool
Old Oct 21, 2004 | 04:56 PM
Crx Jimmy's Avatar
I had that problem with my integra its probably the ignitor in the dizzy( dont buy one of those cheap taiwanese dizzy's that go for $150-200 i went throught two of them in 3 years they are crap!!
Old Oct 21, 2004 | 05:21 PM
1point5CRX's Avatar
Default Re: hesitation/bogging ??!! (Crx Jimmy)
i just threw a code, 15 -- boostedb20vtec said that its a good possibility that its the ignitor in the dizzy. gonna replace that asap
Old Oct 21, 2004 | 07:13 PM
EJ2-Fluffy's Avatar
It does sound like it's misfiring. I've checked each of the connections to the injectors and they are all in the right order. The car runs good after it warms up but still has a bog when going from idle and up.
-Jon
Old Oct 22, 2004 | 06:35 PM
bmoresb16efhatch's Avatar
Default Re: hesitation/bogging ??!! (CRX-Fluffy)
hey had the same prob with my b16 when i put a chipped ecu in it fixed the prob caame to find out not enough fuel turned the fuel pressure up and fixed the prob try that
Old Oct 22, 2004 | 11:45 PM
drussell4801's Avatar
check/replace your plugs/wires
Old Oct 23, 2004 | 12:13 AM
BOSS-REX's Avatar
Bogging at low RPMs is usually from not enough of a fuel shot during hard acceleration, Change the fuel filter and clean the injectors next.
Old Oct 23, 2004 | 12:19 AM
Default Re: hesitation/bogging ??!! (BOSS-REX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOSS-REX &raquo;</TD></TR><TR><TD CLASS="quote">Bogging at low RPMs is usually from not enough of a fuel shot during hard acceleration, Change the fuel filter and clean the injectors next. </TD></TR></TABLE>
INDEED.
Old Oct 23, 2004 | 01:12 AM
Dyn0speed's Avatar
Default Re: hesitation/bogging ??!! (drussell4801)
seems like u have a driveability problem
Old Oct 23, 2004 | 01:28 AM
wu tang's Avatar
Default Re: hesitation/bogging ??!! (Dyn0speed)
have you tried to swap your 02 sensors? my old b16 was doing that. and i swaped out the 2 o2's and ran just fine after that
Old Oct 24, 2004 | 09:50 AM
1point5CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX &raquo;</TD></TR><TR><TD CLASS="quote">i just threw a code, 15 -- boostedb20vtec said that its a good possibility that its the ignitor in the dizzy. gonna replace that asap</TD></TR></TABLE>
ignition.
Old Oct 27, 2004 | 09:18 AM
ovalracer's Avatar
Mine does the same thingv at low rpm.If I hold a steady rpm then floor it it works fine .It also takes a long time to start if I let it sit for a couple of days.It is an 89 SI.
jdm_vtec
13
Jun 5, 2007 03:47 PM
TiMiD703
May 15, 2007 08:59 AM
BlueRex1020
Feb 14, 2007 05:42 AM
Tad
20
Dec 18, 2004 06:11 PM
stRodda
Dec 27, 2003 12:24 PM
