89 TURBO PROJECT
whats up i got an 89 hatch thats recieving a 96 sohc vtec and a turbo kit off of a 91 eagle talon. before im done with it i just wanted some opinions.. P.S. everything on the car right now is stock from 1989. should i change the axels, what kind of oil should i use, should i change the transmission to an si cable tranny? should i lower the compression on the sohc vtec, what stage clutch would be best to put on? and if so, does anyone have a performance clutch for sale? not looking for anything higher than a stage 2, remember its just a dsm turbo. thanks for your help and if u have more suggestions, hit me up.
you have much, much searching to be done, that's the best way to find the answers you want. it sounds like you might want to do a little more research on turbos before you get to involved with the swap
Choplikka
Jan 29, 2004 10:02 PM
