Starting engine cold vs. warm after ECU reset
Old Oct 21, 2004 | 02:00 AM
M1's Avatar
M1
Default Starting engine cold vs. warm after ECU reset
How would each affect things differently? Personally, I've noticed a difference in the way the engine sounds as its rpm raises in 1st gear.
<U>Definitions</U>
-By starting cold I mean the engine has not been run for 15 or so hours and has been sitting outside in 40-50 degree weather, or equivalent.
-Starting warm would mean having been driven around, fully warmed up, just in the past couple of minutes.
Old Oct 21, 2004 | 06:51 AM
PrettyLude's Avatar
it would be better to let it warm up to operating temperatures to ensure oil flow is everywhere throughout the engine
Old Oct 21, 2004 | 07:04 AM
M1's Avatar
M1
Default Re: (PrettyLude)
By this you mean start cold, and let it warm up? Or start warm?
Old Oct 21, 2004 | 07:49 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">it would be better to let it warm up to operating temperatures to ensure oil flow is everywhere throughout the engine</TD></TR></TABLE>
lol, oil goes throughout the engine after a few seconds of starting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M1 &raquo;</TD></TR><TR><TD CLASS="quote">By this you mean start cold, and let it warm up? Or start warm?</TD></TR></TABLE>
when the engine is cold, oil viscosity is not the same as when in operating temperature, thus not allowing the right lubrication.
the engine run rough when cold cause of not being able to create a nice spark
Old Oct 21, 2004 | 08:11 AM
M1's Avatar
M1
Default Re: (mmuller)
When I mentioned the engine sounding differently in the upper half the the rpm range in 1st gear, I mean during subsequent driving after idling for a while following the ecu reset. Both of the times spent driving, the engine was fully warmed up, while one of these driving sessions followed an idling session that started cold.
The difference, thus, is in subsequent performance!
Modified by M1 at 11:46 AM 10/21/2004
Old Oct 22, 2004 | 04:31 AM
EE_Chris's Avatar
Default Re: (M1)
When you reset the ECU, you are resetting fuel trim parameters. My 99 stock hatch typically runs at about +4-5% - this means that the stock ECU fuel maps are a touch lean and so the ECU richens up the mix (by looking at the O2 sensor).
So now, if I reset my ECU, I'll actually run a hair leaner before the ECU re-learns the long term and short term fuel trim values - then things are back the way they were.
69GTOby
Apr 28, 2013 10:02 AM
AJ_doods
May 3, 2011 05:51 AM
GoLowDrew
Mar 1, 2011 09:50 AM
blackcivic11
22
Oct 21, 2009 07:14 PM
mrnewguy
18
Jul 26, 2006 04:35 PM
