What are "valve jobs"
Old Oct 20, 2004 | 09:15 PM
BigC-ivic's Avatar
Default What are "valve jobs"
I honestly don't know
I mean, you can get larger valves, and lighter ones, or different length
but whats with the angles?
Old Oct 20, 2004 | 10:03 PM
zad5's Avatar
u know where the valve sits on the head. imagine a valve installed on teh head the part where the valve touchs the head the outer circle man i should just get you a picture but basically where the valve sits in the head. too make sure there a good seal they do a valve job. valve job also helps with flow of the head its considered one of the most important parts when porting.
Old Oct 22, 2004 | 01:22 PM
BigC-ivic's Avatar
Default Re: (zad5)
so whats the difference between a 3 angle valve job and a 5 angle valve job?
Old Oct 22, 2004 | 01:25 PM
EVOLUTIONINNYC's Avatar
Default Re: (BigC-ivic)
im guessing the angle of the valve seat :dunno:
Old Oct 22, 2004 | 01:47 PM
Rocket's Avatar
Default Re: (SiRhatchalot)
Here is a picture of a "valve job". The angles or radius allows the air to turn the "corner" at low and mid lifts (the most import flow occurs at low and mid lifts). Also a good valve job increases combustion chamber seal. Sealing is a cornerstone to making power.
Old Oct 22, 2004 | 02:23 PM
Default Re: (Rocket)
so when you get a valve job done do you need new valves?
also, is there any down sides to valve jobs?
Old Oct 22, 2004 | 02:46 PM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRhatchalot &raquo;</TD></TR><TR><TD CLASS="quote">so when you get a valve job done do you need new valves?
also, is there any down sides to valve jobs?</TD></TR></TABLE>
No, you can perform a valvejob on the head with the existing valvetrain as long as the valves are in good shap.
As long as the valve job is good (well done and seals good), there shouldn't be any downsides.
cdizzle
Feb 16, 2006 12:33 PM
bukbukintegra
Nov 16, 2005 01:14 AM
VSBB6
Sep 11, 2005 11:07 AM
all motor b20b
Sep 17, 2004 08:50 PM
skribblah
Jun 30, 2003 08:10 PM
