how do u get so low?
Old Oct 20, 2004 | 08:52 PM
TSAngry's Avatar
Default how do u get so low?
im just curious because this has been bugging me lately. im running on omni coilovers with about a little over 2 inch drop in the front and 2 inch in the back. i see these cars slammed with most of their wheels tucked. how do u guys do it without rubbing? when i had my wheels tucked, the front wheels kept rubbing the inner wheel wells whenever i would turn. i mean i never had a problem with the outer fenders or the lining. but i just cant figure out how these people can go that low and not rub.
Old Oct 20, 2004 | 09:19 PM
jojoforhelp's Avatar
Default Re: how do u get so low? (O1Dc2)
The secret, they do rub. You can play with the offset of the wheel and find a happy medium but unless you do alot of cutting and bending, you will rub. Most guy's that do the slammed look dont know that they bump steer around every corner thinking their bad asses....lol
Of course then theres the show cars, they need no explaination.
Old Oct 20, 2004 | 09:27 PM
RidinStock's Avatar
Default Re: how do u get so low? (jojoforhelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojoforhelp &raquo;</TD></TR><TR><TD CLASS="quote">The secret, they do rub. You can play with the offset of the wheel and find a happy medium but unless you do alot of cutting and bending, you will rub. Most guy's that do the slammed look dont know that they bump steer around every corner thinking their bad asses....lol</TD></TR></TABLE>
I'm gonna have to disagree w/ you on that one, my car is as low as the coilovers will go and I have no rub. Am I just lucky or something? Full turns are no problem for me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojoforhelp &raquo;</TD></TR><TR><TD CLASS="quote">Of course then theres the show cars, they need no explaination.</TD></TR></TABLE>
But I do agree w/ you on that one...
Old Oct 20, 2004 | 11:56 PM
honda at heart's Avatar
sorry bad pic...and no rubbing
Old Oct 21, 2004 | 12:53 AM
CircuitFG's Avatar
wheel offsets, tire size, and camber.
Old Oct 21, 2004 | 03:04 AM
markwitdada9
Guest
Posts: n/a
Default Re: (CircuitDA9)
when i was dropped about 3.25-50in in the front and 3in in the back i had no problem with rubbing... maybe it was cause i am running 205-50-15 tires ...but my boys eg is dropped so much that it makes mine look like a 4x4 and mine is dropped2.50in in the front and 2.25in in the back. with his car he cant even turn the wheel all the way... but it looks sic
Old Oct 21, 2004 | 04:35 AM
dFreezy's Avatar
Default Re: (markwitdada9)
usually when your tires rub you can solve the problem by rolling your fenders. thats what i did when i had my EF, no more rubbing.
Old Oct 21, 2004 | 05:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
stock wheels, small tires (195/50-15) and no camber kit = no rubbing.
If you have a camber kit, you'll be more likely to rub or scrape the fender, since the top of the tire gets pushed out.
Old Oct 21, 2004 | 05:11 AM
TeaAddict's Avatar
Default Re: how do u get so low? (i heart my vtec-turbo)
what kind of rims are those?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i heart my vtec-turbo &raquo;</TD></TR><TR><TD CLASS="quote">
sorry bad pic...and no rubbing</TD></TR></TABLE>
Old Oct 21, 2004 | 05:18 AM
dFreezy's Avatar
Default Re: how do u get so low? (TeaAddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict &raquo;</TD></TR><TR><TD CLASS="quote">what kind of rims are those?</TD></TR></TABLE>
work rsz-r
Old Oct 21, 2004 | 06:31 AM
BACKintheDA's Avatar
Default Re: how do u get so low? (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">
work rsz-r</TD></TR></TABLE>
nice car
Old Oct 21, 2004 | 06:41 AM
IntegraLs94Cam's Avatar
Default Re: how do u get so low? (BACKintheDA)
the other way u see cars slammed so much is because they have air bags... and it lets them lower the car really bad.... like the wheel will 1/3 under the wheel well
looks very ricey
Modified by IntegraLs94Cam at 9:48 AM 10/22/2004
Old Oct 21, 2004 | 06:53 AM
TypeR0186's Avatar
Default Re: how do u get so low? (IntegraLs94Cam)
My front are fully slammed on coilovers.
And, NO RUBBING HERE either? 205-40-17" wheels~
Full U-turns etc, and still no rub. Like patrick mentioned above, if you get a camber kit, then thats a different story.
Old Oct 21, 2004 | 07:23 AM
Fabfive's Avatar
Default Re: how do u get so low? (TypeR0186)
No rubbing here either..Im on H&R Race springs on Koni Yellows with the perches on the lowest setting. Im tuckin in the front..the rears arent tucked at all b/c the SRR LCAs kinda raise the *** a little bit.
Im running on 205/40/16 Toyo Proxies on my 16" rims. You can see its got some serious camber, but I havent had any camber wear yet. Ive had these rims/tires for about 3 months now.
Old Oct 21, 2004 | 07:27 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">i other way u see cars slammed so much is because they have air bags... and it lets them lower the car really bad.... like the wheel will 1/3 under the wheel well
looks very ricey</TD></TR></TABLE>
what do air bags have to do with suspension??!
Old Oct 21, 2004 | 07:38 AM
garados's Avatar
air bags or just bags, as in air suspension.
TSAngry's Avatar
yea im running on stock 195/55/15 tires with no camber kit. the thing is, when i was really tucked, i didnt rub the outer fender lining. i rubbed on the inside wheel well whenever i turned.
Old Oct 21, 2004 | 07:41 AM
TSAngry's Avatar
by the way, that black teg on works and the green four door are looking pretty sick.
Old Oct 21, 2004 | 07:43 AM
BigC-ivic's Avatar
do they say NISMO on them?
Old Oct 21, 2004 | 07:46 AM
Fabfive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O1Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">by the way, that black teg on works and the green four door are looking pretty sick. </TD></TR></TABLE>
Thanks man!
But the black DC4 is straight sex!
Old Oct 21, 2004 | 08:37 AM
Default Re: how do u get so low? (BigC-ivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic &raquo;</TD></TR><TR><TD CLASS="quote">do they say NISMO on them?</TD></TR></TABLE>
nope...says rsz-r and they're for sale locally
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AOIFormula &raquo;</TD></TR><TR><TD CLASS="quote"> Thanks man!
But the black DC4 is straight sex! </TD></TR></TABLE>
thanks dude i hella like your car too im lovin your rims gold w/ polished lip = the hottness ....but its a DC2 and im runnin 205/40/16 too, but Dunlop FM901
Old Oct 21, 2004 | 08:44 AM
midwesta's Avatar
u had to know it was a dc2, look at the motor
and those two wingless tegs in the pic with the works are sick.
Old Oct 21, 2004 | 08:49 AM
here's another pic of the drop and shows my friends old teg's ride height too
Old Oct 21, 2004 | 09:50 AM
markwitdada9
Guest
Posts: n/a
i heart my vtec-turbo-sick azz teg bro.. i remember seeing your boys teg on cardomain... howcome he sold it that **** was sick as hell:drools:
Old Oct 21, 2004 | 10:31 AM
Fabfive's Avatar
thanks dude i hella like your car too im lovin your rims gold w/ polished lip = the hottness ....but its a DC2 and im runnin 205/40/16 too, but Dunlop FM901</TD></TR></TABLE>
My bad, I can clearly see the motor, i dont know why I said DC4.
Its hot nonetheless, nice car! Good choice with the shoes!
