2001 ITR: CEL Random Misfire
Old Oct 20, 2004 | 08:11 PM
Beach Accord's Avatar
Default 2001 ITR: CEL Random Misfire
My buddy from Alabama just moved to tampa with his beautiful PY ITR. He pressure washed his engine and a week later he is experiencing hesitation at low rpms and some stuttering at idle.....ECU threw a random misfire code. I checked his spark plugs and sure enough cylinder 3's spark plug chamber had water.... So I had changed all the spark plugs (Denso OEM) and reset the ECU. Drove around for about 20 minutes and no problems... but soon after, the problems start again...this time less hesitation\stuttering, but she still threw the misfire code again. The car has 86K on it. Is it just time to change the plug wires as well? Any ideas?
Random: had to give him some free Honda love....his clutch and brake reservoirs looked like mud so i flushed them till crystal clear. Changed his fuel filter and did a valve adjustment before changing his oil. Boy do I love working on ARRRRRs.
- chris
Old Oct 20, 2004 | 09:37 PM
mikehonda's Avatar
Default Re: 2001 ITR: CEL Random Misfire (Beach Accord)
water in the distributor maybe?
Old Oct 20, 2004 | 09:49 PM
WickedKP's Avatar
Getting new spark plug wire and cleaning the contact point at the coil might help.
Modified by WickedKP at 11:01 PM 10/20/2004
Old Oct 21, 2004 | 07:39 AM
thanks for the replies... I will perform these actions and get back to you
Old Oct 21, 2004 | 08:37 AM
RockstarJR's Avatar
tell him to hide that bitch... They are coming for his next...
Old Oct 21, 2004 | 09:24 AM
encognito's Avatar
Default Re: 2001 ITR: CEL Random Misfire (RockstarJR)
make sure you've cleared the computer.I've done the same thing, minus doing any work to it.Give it time to dry out and reset your ecu
Old Oct 21, 2004 | 09:28 AM
encognito's Avatar
"changed the spark plugs(DENSO OEM)"?
Isn't NGK OEM?
Old Nov 18, 2004 | 08:25 AM
GSR_Jamee's Avatar
Default Re: 2001 ITR: CEL Random Misfire (encognito)
i had the same prob in my GSR....the was water in cylinder 2 &3....i just let it dry out and problem solved (then reset the ECU)...and yes, NGKs are OEM
Old Nov 18, 2004 | 09:55 AM
Philly_NBP_R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by encognito &raquo;</TD></TR><TR><TD CLASS="quote">"changed the spark plugs(DENSO OEM)"?
Isn't NGK OEM?</TD></TR></TABLE>
nope, OEM ITR plugs (at least in the US) are Denso...
Old Nov 18, 2004 | 10:13 AM
Opie's Avatar
You can try to dry out your dizzy as stated above by uncapping it and letting it sit a while. Be careful however if you pull your plug wires out so as to not get any loose debris or other crap in there without you knowing it.
Ef4doorwagon
Feb 22, 2014 08:40 PM
QTKEG6
Jun 23, 2002 10:14 PM
AutoboTxEK
Apr 3, 2002 09:49 AM
98R #448
Jan 2, 2002 07:02 AM
