making a 90 engine fit an 88 tranny
ok..im confused...im getting my 88 si. and the motor is gone. im getting a 90 si motor out of a civic. and putting it in my crx. so what do i need for the converson. thanks for helping me.
he needs the flywheel also i just did a similar thing the 88 pressure plate its different than teh 89-91 the 89 is the same but teh clutch has 20 spline
i ran an 89 si tranny with my zc and it worked fine. i swapped in an 88 si tranny with a 4 puck for the 88, still with my 89 si axles and original zc flywheel (that worked fine with both clutch/tranny combos). everything works fine. all i used was 88 disc and pressure plate.
DO NOT RUN THE 88 CLUTCH... it is the size of a silver dollar..... get a 90-91 pressure plate and flywheel then order a 86-89accord 212mm disc, this is the upgrade size clutch for the 88's and it is a HUGE difference... i did this to my car and i could not belive the size of the 88 next to a 90-91......
good luck
good luck
ok heres my idea. so i get a si motor and get the si tranny. will my shift linkage (88) match up to the 88 shift linkage.
well that didnt make any sense. so let me try it again...i get a 91 si motor with the 91 tranny. will my 88 shift linkage work with it??
CimorelliCRX
16
Dec 12, 2002 05:13 AM
