Differences in d series bottom ends? Specs?
Old Oct 20, 2004 | 06:14 PM
eastbay92cx's Avatar
Default Differences in d series bottom ends? Specs?
I tried searching for a while to no avail. I am wondering about differences between the d blocks. So far I see the dipstick changes places after 95, so does the offset of the crank pulley, etc etc.
My main concern: Does a 1992 D15B8 (civic CX 8 valve motor) have a different crankshaft than a d16z6 or d16y8? I'm thinking about using this block for a build, but if the crank is only good for 1.5L, I might as well wait for another motor / crank. Thanks
Old Oct 21, 2004 | 04:07 AM
civic-4-ges's Avatar
Default Re: Differences in d series bottom ends? Specs? (eastbay92cx)
The crank is fine for 1.6L, not the same as D16z6/D16y8, but not far off. The difference in displacement is from the rod/piston combo
Old Oct 21, 2004 | 06:37 AM
Default Re: Differences in d series bottom ends? Specs? (civic-4-ges)
Are there any strength / reliability differences? In other words, would I be better off to start off with a d16y8 longblock? Thanks again.
Old Oct 21, 2004 | 07:16 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx &raquo;</TD></TR><TR><TD CLASS="quote">My main concern: Does a 1992 D15B8 (civic CX 8 valve motor) have a different crankshaft than a d16z6 or d16y8? I'm thinking about using this block for a build, but if the crank is only good for 1.5L, I might as well wait for another motor / crank. Thanks</TD></TR></TABLE>
yes the cranks are different...
stroke:
d15 - 84.5mm
d16 - 90mm
main journal diameter:
d15 ~ 45mm
d16 ~ 55mm
you cant use a d15 crank in a d16 block...
Old Oct 21, 2004 | 11:06 AM
Default Re: Differences in d series bottom ends? Specs? (fastcrxsi90)
Thanks a lot, I think I'll just wait on a y8 longblock.
HondaCivic541
Nov 26, 2013 04:43 PM
alexsracing
Nov 3, 2005 09:19 AM
turbod96ex
Apr 4, 2004 07:54 AM
RyanEJ8
Apr 17, 2003 05:39 PM
