VTEC wiring need help....
Old Oct 20, 2004 | 06:00 PM
BlownVR's Avatar
Default VTEC wiring need help....
Ok so my friend has a gsr hatch and there are 3 wires cming from his wiring harness at the top part of the engine bay by the battery then 2 wires red and blue that are from the vtec solenoid, i need to know where these wires plug into the ecu at, they came out and i need to put them back in..
Old Oct 20, 2004 | 06:16 PM
eastbay92cx's Avatar
Default Re: VTEC wiring need help.... (slowEKrollin)
try searching 'vtec wiring' archived. I think the red wire you're referring to goes to pin a6 on the ecu (orange with a white stripe) and the blue one goes to pin d4 (white / blue).
DON'T QUOTE me this is only from my failing memory, try the search...
Old Oct 20, 2004 | 06:29 PM
BlownVR's Avatar
Default Re: VTEC wiring need help.... (eastbay92cx)
Thanks alot i will check out the archived content, i only searched recent. thankw for the help
Old Oct 20, 2004 | 06:34 PM
mmuller's Avatar
Mad Scientist
https://honda-tech.com/zerothread?id=650230
Old Oct 21, 2004 | 06:59 AM
BlownVR's Avatar
Default Re: VTEC wiring need help.... (mmuller)
thanks alot i found it
saintbhts
Aug 2, 2014 10:08 AM
Vomit
Aug 24, 2013 11:20 PM
Brian Hinson
Sep 11, 2005 08:50 AM
moose1309
May 18, 2004 07:31 AM
teg2000
Nov 6, 2003 03:29 PM
