rain puddle + AC,PS, Engine Pullys =annoying noise
Old Oct 20, 2004 | 04:06 PM
PLAGUED_DB7's Avatar
Default rain puddle + AC,PS, Engine Pullys =annoying noise
last night I didnt see a puddle when I was leaving work...it soaked the engine bay pretty good...this am when I started the car my pully (or pullys) are squeaking...
any idea on how to get rid of that? WD40, or some grease?? it only last about 2-3 miles, and only happens at idle... after that I can turn the car off (4hours) then start it up to go out for lunch and no squeaking...thanks.
Old Oct 20, 2004 | 04:10 PM
gsrboi80's Avatar
Default Re: rain puddle + AC,PS, Engine Pullys =annoying noise (PLAGUED)
probably just had a little sitting on the belt/pulley. It should be fine if you want they sell somthing called belt dressing (local auto parts store). Put some of that on your belts
Old Oct 20, 2004 | 04:13 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: rain puddle + AC,PS, Engine Pullys =annoying noise (gsrboi80)
are you sure it's your pulleys and not the belt slipping on them? Check the tension. That sounds more like your problem.
Old Oct 20, 2004 | 06:26 PM
G1 TEGGY's Avatar
Default Re: rain puddle + AC,PS, Engine Pullys =annoying noise (marsbike)
rub a bar of soap (not rub the whole bar though) on the belts that are affected, easy fix
Old Oct 20, 2004 | 08:21 PM
Default Re: rain puddle + AC,PS, Engine Pullys =annoying noise (G1_TEGGY)
belts have good tension...they were replaced when I got the car in Feb. I will check tension in the am... thanks for the help
onnoff7
Jan 25, 2006 12:50 PM
fangtl
Jan 4, 2005 02:15 PM
pbizzlegsr
Mar 1, 2004 05:09 PM
-iLLuZioN-B18C1
Jan 8, 2003 06:16 PM
hobo79
Feb 22, 2002 03:40 PM
