small gas leak with tank full
i have ben having this problem for a while now, whenever ui fill my gas tank above 3/4 tNK and go for a drive whenever i pull in my driveway and let the car sit, gas will drip for a couple seconds then stop, also when im in the car i have a real bad smell of gas, i was just wondring what would cause this, it only leaks while i am driving and when i stop for a couple seconds with 3/4 tank it makes no sense anyone have any ideas???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 »</TD></TR><TR><TD CLASS="quote">hondaguyef had same problem. A hose was not sealing correctly....think its time you dropped your tank buddy and buy some new hoses before you do.
DEF</TD></TR></TABLE>
How do i know what hoses, and how could a hose cause it only to leak after im done driveing??
Take it to a shop.... TRUST me. With a tank that old, on a car that old, if they break something, they can usually fix it. You probably won't be able to without a HUGE-*** headache.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R »</TD></TR><TR><TD CLASS="quote">drop your tank, it sounds like the hoses not sealing leading out of your fuel pump.</TD></TR></TABLE>
Which is caused by those POS metal line fittings getting pinholes in them. Good luck with those. Take it to a shop... PLEEEEEASE. Trust Vash.
