what would happen if my JDM itr header is touching the oil pan??
Old Oct 20, 2004 | 03:16 PM
trustbuddy's Avatar
Default what would happen if my JDM itr header is touching the oil pan??
i searched and someone mentioned "bending" (although i don't quite understand how this is possible) the oil pan. what can i do to fix or work around it??
And as the title states, what would happen if i drive around with my header touching the oil pan???
Old Oct 20, 2004 | 04:45 PM
Integrt's Avatar
Default Re: what would happen if my JDM itr header is touching the oil pan?? (trustbuddy)
wrapp the bottom of the header with heat wrap or cover it somehow.
had the same problem with my friends turbo delsol. u don't want it to melt the oil pan
Old Oct 20, 2004 | 06:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
ummm why is it rubbing the oil pan? Did you hit something that pushed it up into the oil pan? Are you not using the bracket that hangs down behind the engine that the collector is supposed to bolt to?
Old Oct 20, 2004 | 06:40 PM
localmotion's Avatar
If you leave header tuoching the oil pan you'll over heat the oil and break down the lubrication factor.
DC2-ProdUcTiOnS
May 24, 2009 06:46 PM
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
cyrix12
Mar 6, 2006 10:30 PM
LSVTEC 91 Civic
Jul 25, 2005 10:25 AM
Shakes
Mar 28, 2004 07:25 AM
