what kind of greas do you guys use in your axle boots?
Old Oct 20, 2004 | 01:32 PM
GOTNOS's Avatar
Default what kind of greas do you guys use in your axle boots?
i just got my car off the jack stands a few days agao drove it around im getting a lil vibration from the left side and i dont think the boot that connects to the ttransmision spidle is on good may be lacking some lube so ima lube it up whats the best or cheapest kind i could use. Also can i buy a new axle boot clap? or shoul di use just a cheap ol screw tightened clamp.
Modified by GOTNOS at 12:55 PM 10/21/2004
Old Oct 20, 2004 | 04:02 PM
2point2's Avatar
Default Re: what kind of greas do you guys use in your axle boots? (GOTNOS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOTNOS &raquo;</TD></TR><TR><TD CLASS="quote">ima lube it up </TD></TR></TABLE>
haha..
You can get the boot, clamp and grease all in one kit usually.. It might even be cheaper to buy the kit and you end up with a spare boot.
forget about the 'screw' clamp, you dont want the chance of causing a differn't vibration from that style clamp. Basically, if the clamp is not the same style as the stock one then DONT use it. buy the kit from a place that does a loan-a-tool and use the proper tool to clamp the boot on.
good luck.
Old Oct 20, 2004 | 08:30 PM
GOTNOS's Avatar
Default Re: what kind of greas do you guys use in your axle boots? (2point2)
is it possible to fix all this with the axle still in place? I would hate to have to undo all that bs again .
Old Oct 20, 2004 | 09:38 PM
ChrisRicketts's Avatar
i use jerry curl juice.
Old Oct 21, 2004 | 12:17 AM
BrokeLude's Avatar
Default Re: what kind of greas do you guys use in your axle boots? (ChrisRicketts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">i use jerry curl juice. </TD></TR></TABLE>
How do you keep your seats clean???
Old Oct 21, 2004 | 12:55 AM
GOTNOS's Avatar
Default Re: what kind of greas do you guys use in your axle boots? (BrokeLude)
he keeps the plastic on them.
Old Oct 21, 2004 | 06:41 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOTNOS &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to fix all this with the axle still in place? I would hate to have to undo all that bs again .</TD></TR></TABLE>
It would probably be a pretty messy job in the driveway... Just pull it out, it's good practice.
wear rubber gloves.
Old Oct 21, 2004 | 07:22 AM
kellyk75's Avatar
If you don't need to clean all of the old grease out & just want to add some, you can just take off the outer strap, scrape some of the old grease out & squirt some new grease in & put on a new strap.......... without taking it off the car.
Old Oct 21, 2004 | 10:46 AM
LudeyKrus's Avatar
Damn, that job is BITCH!!!
I had to do that before.........
I used Valvoline's grease in a can for about 5 bucks from Advanced Auto. Get a good clean area to work, and plenty of rubber gloves. I also used brake cleaner to clean things when I got them dirty and needed to clean off the grease.
Good luck!
civicdelsol33
12
Dec 2, 2008 09:22 PM
instrument
Apr 28, 2006 07:15 AM
redryder
Aug 28, 2005 07:33 PM
94lsboost
Oct 21, 2003 10:52 AM
