99 ls distributor wiring
Old Oct 20, 2004 | 10:12 AM
kyden's Avatar
Default 99 ls distributor wiring
b18b in a 99 civic dx, si wiring harness... the ls distributor has 9 wires, and the si plug has 8 wires.. it seems there's an extra blue wire next to the black/yellow wire.. what is the blue wire for? also on the LS harness, the black/yellow wire is thicker than the other wires, and on the si harness, the black/yellow wire is the same gauge as the rest of them.. is that a problem?
Old Oct 21, 2004 | 06:28 PM
kyden's Avatar
Default Re: 99 ls distributor wiring (kyden)
anyone?
Old Oct 22, 2004 | 05:24 AM
JimBlake's Avatar
Is the blue wire for the tachometer signal? Maybe the dx doesn't have a tach?
Old Oct 22, 2004 | 08:25 AM
kyden's Avatar
Default Re: 99 ls distributor wiring (JimBlake)
the dx has a tach wire.. but the harness is from an si..
Old Oct 22, 2004 | 08:39 PM
kyden's Avatar
someone?
Old Oct 25, 2004 | 03:56 AM
JimBlake's Avatar
I looked at the wiring for our '98 Accord. The tachometer is driven by the ECU, so there's no blue tach wire coming from the distributor. It's also only got a CYP sensor in the distributor, no CKP or TDC. So you can't really count on different years & different models to be the same. To really answer your question completely, you'll need THREE wiring diagrams; Your car, the SI where you got the harness, & the Integra where you got the engine. Don't forget they're different from year to year, too...
Old Oct 31, 2004 | 06:30 PM
AZSTATEPOLICE's Avatar
The missing tach signal wire is not a problem, the ECU still sees it. If you still dont have an RPM gauge on your cluster it is not a problem.
RocHatchDX
May 26, 2014 12:27 PM
nonvtec
Apr 5, 2005 11:11 AM
bogus_ek
Mar 27, 2005 08:10 AM
dawrenn
25
Nov 4, 2004 05:06 PM
serious
Jan 19, 2003 02:42 PM
