Swap won't run unless throttle is open, HELP!
Old Oct 20, 2004 | 10:01 AM
AC2i0v0i0c's Avatar
Default Swap won't run unless throttle is open, HELP!
Can't figure out why my car won't start unless throttle is open. When released the car dies, anyone know what could be the problem?
Old Oct 20, 2004 | 05:41 PM
rhetorical's Avatar
What engine into what car? I've got the same problem in my B18C5 (in a '88 CRX)
Old Oct 20, 2004 | 05:55 PM
eastbay92cx's Avatar
Default Re: (rhetorical)
See if the idle valve on the bottom of the throttle body is working correctly, or else just adjust the idle screw that opens up the butterfly a little bit.
But honestly, with the problem you guys are having, it's more important to make sure that everything is connected properly and that the motor has the right ecu (or chip) running it. You shouldn't need to adjust that screw to open the tb to make it idle. Good luck.
Old Oct 20, 2004 | 08:48 PM
hondaZvic's Avatar
Default Re: (eastbay92cx)
hm... it does kinda sound like some kind of throttle body issue or timing maybe?.. eh.. hard to say..
Old Oct 20, 2004 | 09:50 PM
Prod's Avatar
Default Re: (hondaZvic)
maybe a silly question but is there too much slack in the throttle cable ?
Old Oct 21, 2004 | 07:57 AM
AC2i0v0i0c's Avatar
b18c5 in 96 cx
Old Oct 21, 2004 | 07:58 AM
AC2i0v0i0c's Avatar
Default Re: (Prod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prod &raquo;</TD></TR><TR><TD CLASS="quote">maybe a silly question but is there too much slack in the throttle cable ?</TD></TR></TABLE>
Nope, checked that also.
Old Oct 21, 2004 | 08:01 AM
AC2i0v0i0c's Avatar
But honestly, with the problem you guys are having, it's more important to make sure that everything is connected properly and that the motor has the right ecu (or chip) running it. You shouldn't need to adjust that screw to open the tb to make it idle. Good luck.[/QUOTE]
00 b18c5, using a 98 b18c5 ecu
Old Oct 21, 2004 | 08:08 AM
Prod's Avatar
Default Re: (AC2i0v0i0c)
no codes ?
import-tooner
Jul 19, 2013 06:39 AM
beefjerky
Oct 22, 2007 09:55 AM
cbcrx87
Aug 13, 2006 10:32 AM
sixleggedbandit
May 1, 2003 03:59 PM
