1994 LS IGNITION TIMING.......
recently my car was stolen.....i have goten it back and its back on the street and i was told i have to set the ignition timing............how do i do this........it is a 1994 ls vtech engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue »</TD></TR><TR><TD CLASS="quote">... you need to locate the timing its right next to the gas tank...</TD></TR></TABLE>Yes, that's really clever. We're all impressed.
Do you have a timing light? They'll have instructions. Hondas don't have degree marks on the flywheel, there's notches in the edge of the crankshaft pulley at the front.
There's a single notch (that's TDC), & a little bit to the left are 3 marks together. The bigger center one is stock spark timing, with the +/- 2 degrees tolerance indicated by the smaller ones. The pointer is molded into the plastic lower timing-belt cover. Loosen the distributor mounting bolts & twist it to adjust.
VSM EXtasy
Jul 19, 2003 10:19 AM
