The Ultimate Turbo/Injector/Power Calculator!!
Well,
I finally finished messing with it and here it is. I re-did about 25% of this thing that i got from a friend to more accurately reflect modern high output 4 cyl engines. plus i added some additional calcs and revised the presentationa bit.
if you have any quesitons there is a second page called "help" which tries to answer any quesitons!
http://web.tampabay.rr.com/enthalpy/turbocalc/
it's the only file in there!!
As you download it you will find it is currently setup for a turbo like a GT35R running 21 psi manifold pressure on a highly modified 2.0L SR.
enjoy and discuss!!
enjoy and discuss!!
Updated spreadsheet posted with some changes to intake and exhaust k values and a heavily revised exhaust MW value and WG flow percentage. I forgot this thing was originally written for 3.8L turbo engines...not 2.0L
it makes alot more sense now
I'm having problems using it --- I downloaded it but its asks me what program do I want to use it use it.
ie : windows media, Real player, IBM imaging connections, Acrobat reader
Help, I want to use. .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">What is a good VE value for a stock DOHC VTEC motor? (i've always wanted to know this)</TD></TR></TABLE>
I always thought it was around 85%
*edit*
broguht this thread back from the dead, and I didn't even realize it
*edit*
