LS+GSR pistons?
Old Oct 20, 2004 | 04:49 AM
parks's Avatar
Default LS+GSR pistons?
is this possible with stock rods? I thought about others like ITR, CTR but this is my daily driver and wanted a reasonable CP without havin to run 93+ octane everyday.
More than likely will jump into a Vtec head in the spring time with more funds so its a build in progress .....
Old Oct 20, 2004 | 06:34 AM
b19coupe's Avatar
Default Re: LS+GSR pistons? (parks)
Yes. You have to have either the rods or pistons modified to fit. The small end of the LS rod is too wide to fit in an unmodified GSR piston.
Old Oct 21, 2004 | 12:59 PM
parks's Avatar
Default Re: LS+GSR pistons? (b19coupe)
so for the trouble, i should just go with the itr's?
91 octance alrite?
Old Oct 21, 2004 | 04:25 PM
b19coupe's Avatar
ITR pistons are fine with 91 octane-properly tuned.
Old Oct 21, 2004 | 05:42 PM
Steemo's Avatar
usdm itr pistons will give you about 10.3:1 cp while the jdm itr pistons will take you up to about 10.8:1 either way you should be able to run on pump gas easily when tuned.
darkintegra
Apr 17, 2007 07:42 AM
lscoupe
Mar 10, 2005 03:07 PM
WhiteDC4
Apr 6, 2004 09:32 PM
B16beatdown
Mar 17, 2004 11:15 AM
B00ST2nR
Apr 28, 2002 10:58 PM
