neuspeed koni yellow question
since the sport koni yellows have adjustable perches that let u drop the rear about 15mm, how much will the neuspeed version be able to drop to? 25mm? also how much up front? are the 5 perches for both front and back? thanks guys.
Modified by diluted at 10:10 PM 10/20/2004
what? shocks have nothing to do with ride height... thats springs. Now if your talking about how much you are able to drop your car with those installed. Koni's will work very well at way more than 25 mm. 25mm is only an inch. My car is dropped way more than an inch and I have koni yellows.
um, koni yellows have adjustable perches that let u adjust the ride height a little. im asking this question because id like to lower the rear a little more to even out the ride w/ my current springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diluted »</TD></TR><TR><TD CLASS="quote">um, koni yellows have adjustable perches that let u adjust the ride height a little. im asking this question because id like to lower the rear a little more to even out the ride w/ my current springs.</TD></TR></TABLE>
i'm not sure what the reg yellow is like, but i imagine that they share the same middle perch setting as the neuspeed yellow.
it appears that the gap between perch settings on the yellow is roughly 5-8mm.
if anything, put the perch setting in front 1 above center, and the one in the rear 1 lower than center.
thanks for the replies. right now i'm on H&R race springs and i have a gap of 1 finger up front, and two in the rear. do u guys think the regular koni yellows will let me close the rear gap?
