Need help D16a6 w/z6 IM
Old Oct 19, 2004 | 10:52 PM
civicdust's Avatar
Default Need help D16a6 w/z6 IM
I try to search and not ask alot of questions, but when you cant find the answer you're pretty much determined to ask it here..
SO here it goes...
My setup:
91 d16a6 motor on a d16z6 intake manifold
88 honda civic std converted MPFI
Problem:
Im getting code 10 and 7.
7 is throttle sensor. What can i do to fix this? am i suppost to move something to align it right? or just get something new??
10 is IAT, i know what that is, but what can be causing it to pop up? and is this located just like it is in a b16 IM? (its raining, so i cant check)
My car turns on, but when i press the gas to rev it, it bogs, and feels like its going to turn off. if i put it in first, and try to move it , it will hardly move...not enough power??
anyways, if you need anything else let me know..
Thanks again
Old Oct 20, 2004 | 12:09 AM
Fobtions's Avatar
Default Re: Need help D16a6 w/z6 IM (JoseDM)
sounds like you got it switched.
take the throttle body plug and plug it into the sensor on the back of the intake manifold.
might need to do some extending
Old Oct 20, 2004 | 12:42 AM
civicdust's Avatar
Default Re: Need help D16a6 w/z6 IM (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you got it switched.
might need to do some extending</TD></TR></TABLE>
wil try
Old Oct 20, 2004 | 05:59 AM
crx_88_si's Avatar
did u swap the wires on the TPS?
Old Oct 20, 2004 | 07:02 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
either the iat is bad or not plugged in...and yes it is on the manifold.
also, either your tps is bad or needs to be calibrated. its most likely bad if your having those problems though.
Old Oct 20, 2004 | 07:22 PM
civicdust's Avatar
Default Re: Need help D16a6 w/z6 IM (fastcrxsi90)
well now all i am getting is a code 10..
i try to run the car, and it moves, but when you floor it, it takes forever to get upto speed, and when it reaches about 20 mph it bogs, and resumes at about 25.
(i dont have rpm, yet)
i need this ****** running good
Old Oct 20, 2004 | 07:24 PM
civicdust's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">either the iat is bad or not plugged in...and yes it is on the manifold.
also, either your tps is bad or needs to be calibrated. its most likely bad if your having those problems though.</TD></TR></TABLE>
where in the manifold? is it the ciylinder shaped...thing?
also, does anyone know if a map sensor is on the manifold? my car didnt come with one..
dont know if the previous owner switched it, but i am guessing yes
Old Oct 20, 2004 | 08:50 PM
civicdust's Avatar
Could not having a map sensor, cause this??
senate33
Nov 20, 2014 11:03 PM
cougar289
Apr 11, 2009 07:48 AM
thesoundofturbo
Oct 31, 2007 06:43 PM
SOHC_Brian
Jan 2, 2004 01:32 PM
Brownjd
Oct 30, 2003 08:55 PM
