Quick Question About Motor Swap, Need Opinions!
Im kinda in a little Delima, I want to buy a swap for my hatch (95 Civic Cx Hatchback) and Need some help on which motor to buy, Im on a tight budget and only have about 2.500 to spend. Thats where u guys come in, Should I Buy:
A. B16A (XSI) http://www.hmotorsonline.com/s...30003
B. B16A (SiR2) http://www.hmotorsonline.com/s...30005
What are the differnces between the two B16's???
Is there any other things I would need for the swap other then what hmotor is giving me?)?
or should I try to get more money and go GSR?
Im pretty confused here and cant make my mind up!
I apprecieate Anyone who helps me out!
If I do get the siR2 which tranny should I go with?
Thanks GUYS
Thanks GUYS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flappy188 »</TD></TR><TR><TD CLASS="quote">or should I try to get more money and go GSR? </TD></TR></TABLE>
this sounds good to me.
If you only have 2500 total for the swap, I would say plan carefully and make sure you have extra for the little things that are forgotten sometimes. Timing belt, water pump replacement, new plugs, belts... Etc. Now would be a great time for a flywheel and clutch upgrade while the motor is out. I wish I had gotten a flywheel while I was replacing the clutch. But, like you, I was on a budget!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaybee »</TD></TR><TR><TD CLASS="quote">I have a GSR and it feels good compare to my friends B16A2 EK...I have one in an EG...Go with an LS over B16...For that low end of course....</TD></TR></TABLE>
I have less than 1500 in my ls swap but it took a while to piece together. You can plan on spending @4-500 in random expenses after the swap, god help you if you have problems with any cels. The ls has alot more torque than a b16 as mentioned before, but if your a vtec feind you might aswell go with it because some people just are not happy with out their vtec fix. just remember hp #'s are good to have but if you don't have any torque with it, it's just going to be a noise maker
BabyHatchBack
Aug 22, 2005 02:07 PM
Hatch It
Apr 7, 2005 07:46 PM
